L35
Jun 13, 2010
641
693
CT
I had some mature shrubs up and die over the winter, must of been too cold as I’ve seen alot dead rhododendron and juniper after this winter that usually survives. Used the hoe to rip them out and forks to move them to a staging area before disposal. It’s a shame as they finally had spread to the size I needed to cover a area Now to decide what to plant next.
old and tired
L2800 HST; 2005; R4
I had some mature shrubs up and die over the winter, must of been too cold...
Sort of, what most likely happen was that weather warmed up enough to break winter dormancy (got water flowing into the plant when warm) then it got down below freezing and the water in the plant cells froze and broke the cells. Plants can handle deep cold if it's dormant... but it's when it freezes after dormancy is broken, that's the (new) problem.
6,166
I built a simple raised flower bed for my sunflowers I grow every year. I made it out of pressure treated and boy that sucker was HEAVY.
Not heavy for the tractor tho 😁
This tractor is making me lazy.
Just wait until you get yourself a set of forks...;)
6,166
Horse hay today...It really doesn't look edible to me.
While doing so, I picked up a flail mowing, grading and seeding job while I was there. That's fine with me as I have chosen not to advertise this year. I'm trying to get away from "landscaping" jobs. They are no longer any fun for me.
Hugo Habicht
G1900
Jun 24, 2024
1,064
1,547
Ireland
I'd have to go out in the back forty to change it, just had to move it a short distance but long enough to be a pita by hand kinda thing.
You need a second tractor. Definitely. You can leave the forks on this one then. Sell the washing machine and you have the deposit.
S-G-R
Grand L5460, X1100C RTV
Jun 17, 2020
1,543
3,794
PEI Canada
Loaded up the BTR and planted 30 trees.
Reactions: 10 users
S-G-R
Jun 17, 2020
1,543
3,794
PEI Canada
On to mowing
Had the neighbor spraying
Reactions: 6 users
6,166
Neighbor decided she wanted to convert her weeded woods into grass...quickly.
I was planning on hitting it with the flail then grading it. Decided to skip a step and get it done for her this evening.
The EA rake is a beast.
I probably shouldn't have rescheduled my 30 yr anniversary dinner tonight?
Reactions: 10 users
Ultramaroon
KUBOTA L2501HST, LA526. LAND PRIDE BB1260 RCR1260
Mar 26, 2025
Centerville, Texas
I mowed my "ag acre" which is really just an acre overseeded with Spring and Fall wildlife mix and clover. Also mowed the road frontage which is 900 feet by about 40 to 50 feet deep back to the tree line.
S-G-R
Jun 17, 2020
1,543
3,794
PEI Canada
Is he staying round up or furtilizer?
I'm not sure what he was spraying. The land hasn't been worked yet. Last years crop was potato's so I'm guessing grain or corn for this year.
10,009
I got back home around 5.45pm today after close to 3,400 miles of driving. I picked up the new bumper for the F-450 this morning in Moore, MT and drove about 350 miles with it strapped to the new trailer.
Within 20 minutes of getting home, I fired up the MX and took the bumper off the trailer and put it in the garage out of the weather. I'm probably going to use the MX with pallet forks to hang the bumper for final prep and painting, and to install it on the truck. It weighs a little over 300lb.
Reactions: 9 users
GrumpyFarmer
4,521
Oh my…that looks a lot like my ARB (minus the winch mount) on steroids! 👍
GrumpyFarmer
4,521
Very Nice implement. 👍
It’s next on my bucket list. Couple questions:
1. Can your rake grass effectively without ripping out the grass with that? Is it reasonable to think you go rake a large lawn with that and maybe offset the blade at an angle to make a winrow, so you could come back and collect with the bucket? Could you do that with grass and leaves without destroying the lawn?
2. in your opinion, is there any reason to add hydraulics to it or reason not include hydraulics on that implement?
thanks.
6,166
Not really, you'd tear out the grass. Some success when pushing the rake backwards but it's of limited utility. I'd think that you'd be better served with a spring rake/de-thatcher.
Not that I see. I wouldn't bother with the extra associated costs for hydraulics. I would say that the gauge wheels (although expensive) are worth the investment.
thanks.
Short answer to both of your questions would be "No".
7,205
On that style of rake if you shorten the top link so the bottom of the rake teeth lay as flat as possible it can be use to rake without digging into the surface. I do that with a 7' to spread cow pies!
