Off road, dumping trailer?
Blue2Orange
Apr 3, 2025
396
276
Bayview Township
Downsized to the BX. Thinking about eventually purchasing a smaller "wood hauling" trailer. Max capacity of 1/2 ton. Keep me from doing something stupid vs. using the existing trailer.
Any experience and recommendations with a model that has a dump feature? Locally (within an hours drive) we have a Tractor Supply and a L&M Fleet for stores. Plus my Kubota/New Holland dealer. Those would be my first choices of retailers.
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,895
2,311
Western MT
There are a few trailers on Amazon with single and double axles and atv tires.
bobnic
LX4020, BX2370, KX033, Ford 8N
Mar 7, 2025
121
118
Lakes Region, NH
I have two manual dump trailers that I have had for years and been very happy with:
One is from Tractor Supply the Ohio Steel Tow-Behind 15 cu. ft. Hybrid ATV and Lawn/Garden Poly Swivel Dump Cart, 1,250 lb. Capacity.
The other is heavier duty, about twice the cost, and has a bit larger 1600lb capacity from countryatv.com. It's their single axle 5450ATV dump trailer.
Both are very rugged and handle rough terrain well. I have used them behind my ATV and tractor for hauling firewood, gravel, and stone.
3,480
Here is what I use:
Post #9
ItBmine
B2620, RTV-X1100C
Jan 21, 2014
1,520
548
I was going to buy one of these for my B2620. Weber Lane hydraulic dump trailers. They come in 1 to 4 ton capacity. Come standard with a hand pump hydraulic cylinder, but I was going to use my rear remote to dump it.
But then I ended up buying my RTV-X1100C to use as a dump truck instead.
William1
BX25D, JD X754 AWS Mower
Jul 28, 2015
1,398
599
Richmond, Virginia
Off road? Hard pack, mud, sand, thorns?
I would love to have a 3 cubic yard mini dump trailer but, physical dimensions size can't be wider than the BX (48"). So I use a 1/2 C.Y. crappy thing but, I got rid of the narrow, wheel barrow tires and put on 6' wide (like of the front of a garden tractor) to help prevent sinking in the soft stuff. I've way over loaded it several times (amazed the axle did not bend). Very similar to the green one Lil' Foot refereed to.
What trailer depends on what your expectations are.
6,243
whatever you buy be real careful hauling it loaded ! BX isn't noted for great braking and 1000# behind going down a slight grade, will be 'interesting'
ideally the trailer should have brakes and a 'power' lift of the box. If it has a hand crank, add a 12v winch to it.
Blue2Orange
Apr 3, 2025
396
276
Bayview Township
One reason why looking for a small off road trailer. NH was a compact that outweighed the BX by a good half ton. The front wheels of the NH are larger than the BX's back wheels. Such tiny front wheels on the BX.
Pulling the current trailer when loaded to the max was "interesting" heading downhill using the NH. No way with the BX considering the pitches going up and downhill on the property.
The trailer owned is a 5x8, 2000# gross, max load of 1525#. I though just enough to transport the BX . Checking the tire pressure yesterday noted, 1375max load at 50psi. Trailer has become of limited use. Or find some tires capable of higher loads. Hopefully can sell it for enough to cover the costs of a quality smaller capacity utility trailer. Then either hope my Kubota dealer has trailer rentals if I need to get it to the shop or $$$s. He did note as he saw my eyeballs lusting for a few new implements that everything is available for rental. I think I was staring at the scraper grader box too much.
jimh406
Jan 29, 2021
2,895
2,311
Western MT
I built a small trailer (4x6) using the 2 year old fronts from my BX23S. They're 4on4, so 2000# trailer axle size! Sold it before I could use it.
I was going to build one, but then I found the trailers on Amazon with dual axles for less than I could build one for. I'm not sure how they sell them so cheap.
bjmsam
L3710 HST
Feb 19, 2010
30
12
Mount Airy, MD
For anyone considering a VEVOR dump trailer, cargo area dimensions are not stated clearly in the listings, so I pointed ChatGPT at "Carriage Size" specifications in the user manuals to generate this comparison for convenience:
TC4268 1500 lbs 15 cu ft $275 (manual)
TC4278 1600 lbs 22 cu ft $299 (manual)
TC4288 1800 lbs 28 cu ft $456 (manual)
The TC4268 seems too small and the TC4288 seems too expensive so I ordered the Goldilocks TC4278 with KFFKFF branding from Walmart for $273.
Sidekick
Jul 29, 2023
1,206
1,735
N.Y,
The tires on them are very thin with tiny axles. I doubt they would last long in the woods.
g_man
Feb 3, 2023
367
1,696
NE Vermont
I bought a used 1.5 ton Pronovost that I pull with the L3010. It has removable front, side, and tail gate panels. And the tail gate hinges from the top or the bottom.
It will haul a yard of gravel.
I added some stake pockets and rub rail side stiffeners and also a 1-1/4" Reese hitch to make it more versatile.
gg
