Once I figure out how to fly this drone...![]()
Unloading/Loading The Kubota SVL From Equipment Trailer
Enjoy the videos and music you love, upload original content, and share it all with friends, family, and the world on YouTube.youtube.com
I forgot to take before pics. Anyways, I exceeded the customers expectations, which I always try and do anyways. She sent me the pictures she had. I basically cleared an acre of really thick South Texas Trees/Brush, everything I cleared off was invasive species, to include the mesquites. The mesquite tree is one of the toughest, most invasive species of brush in the world.
The area on the other side the fence, or behind that trailer. I probably moved 10 tons of prickly pear to the burn piles, I ran out of trees and brush to move even more Cactus. I drop the trees and brush on the prickly pear and use that as a means to grab all the pads. A few of the Cactuses were the size of small cars.
Before
Afta
Finally found a more reasonable solution to the stone-in-the-lawn problem: Wide skid shoes on a snow blower. Personally I'd use steel bar so the shoes last longer, but plastic can be a quick and cheap way to see what works. I made "wide" (though not wide enough for a gravel drive) steel skid shoes for the rather large hydrostatic walk-behind blower I modified in several unconventional ways and they work great with barely any wear after years of use and do not damage the concrete drive I use it on. The idea should work even better on a gravel drive.Yes the pads are adjustable but they are already set where I'd normally put them. I usually take them off when the ground freezes. They are like 3 times the size of the ones there were on my side by side plow but as low as they are, they just prevent the plow from really scraping.
It's inevitable. Even when I had the side by side, I always had significant amount of stones in the lawn after plowing season. I'm limited to where I can put the snow so I spend every spring getting blisters raking my 500ft drive way up and down. Good exercise I guess lol. But in a way I think the tractor may actually be better because I don't need to push the snow further. I can just make one big snow bank and dump it over. The side by side just builds up and by the end of the season there less room in the drive way.
Yes I'm gonna have work to do this spring. I'm a new tractor operator so I'm gonna make mistakes and rest things up a little but that's ok.
You should see other people's drive ways who get plowed out with a pick up. Nothing like seeing mounds of sod piled up. I am not where close to that level of damage!!!!
The damage I caused is minor in comparison and plus it's another excuse to use the tractor
A power broom would be awesome to own. I might have to look into that.
Impressive! That's a lot of stacking.55* here today. Brought up 4 tractor buckets of firewood to replenish what I've used. Unbelievable weather. I looked on Reynolds Motorsports website today.
ALL snowmobiles are on sale, imagine that...lol. In the past week here in Maine four people have fallen thru thin ice in different areas of the state.(stupid). None drown , all were pull out. As the water was shallow.
The wood is brought up today is a mix of
red oak, beech and maple all three yrs split and stacked.
I'd sooner mow then blow snow. We've missed most of the snow so far but my luck will run out eventually.
No shortage of cold and snow here if you want some. Was -43c with the windchill last night.I'd sooner mow then blow snow. We've missed most of the snow so far but my luck will run out eventually.
We were a balmy +6C on PEI today.No shortage of cold and snow here if you want some. Was -43c with the windchill last night.![]()
Farmers almanac for what it is worth, is calling for a mild dry winter for Atlantic CanadaWe were a balmy +6C on PEI today.
I love the looks of those B6000 tractors. They can do a lot of work too. A neighbor has one. No loader on his though.Plowed some snow for the first time with the B6000.
It worked great even plowing up some steep hills.
Just got a picture from the security camera.
