Check your tire pressure!
Yooper
3901 LA525
May 31, 2015
1,733
910
NE Wisconsin
Had a friend with a big skid steer with a stump bucket remove a 40" red maple stump. This was the right call because it was so big and so deep. But it weighs over two tons because he could not lift it with his unit. So we decided to drag it with my tractor with him pushing it. Well, had the tractor in low and we were making progress until the stump got a little sideways and I ended up rolling the bead of the tire off the rim. Rim Guard gushing out everywhere.
It was too far from the shop to get and air hose to so I tried to cinch it up with a load strap at first and then a come along and trying to get it to bead with a portable air tank. Not even close! So pull off all the weights and remove the rim and tire and roll it over to the shop where I could blast it with some decent air pressure and volume. It worked but I got to say, It gave me a pretty good workout!
Got the tractor back to the shop and decided to check all the tires. Right rear only had 9psi and the fronts were 20psi and 25psi. Operators manual says 30psi in all four corners. Serves me right for not keeping up with a simple maintenance procedure! Thought I'd pass this lesson along.
Reactions: 8 users
5,501
Glad you got her all pumped back up !
Trimley
BX23SLSB-R-1 plus additions
Jul 25, 2023
1,181
872
PNW-WA
Seeing the size of the thing wearing the floppy shoe, I can imagine that was a chore.
MAArcher
Kubota B8200
Oct 6, 2022
116
47
New England
Hate to admit this, but at the beginning of the summer I swapped AG tires and rims over to turf. Last time I mowed I hoped off the tractor to pick up a branch that had come down and notice only two of six lug nuts holding a rear tire on and the remaining two only had a couple threads holding them on. I'll be adding "check tires aren't falling off" to the preflight check list along with check air pressure.
WFM
L3800
Apr 5, 2013
1,573
1,051
Porter Maine
That stinks...glad you got it fixed.
I never knew until this past summer that there was such a thing as a 'wet tire presser gauge ' to check filled tires.
My rear tires were practically 0.
I'm very fortunate I didn't have a big blow out or splash down.
trial and error
Feb 16, 2023
394
386
NY
That's no fun I recently was lifting an old "trailer" axle into my trailer using the fel, as I was pulling up to the trailer I was wondering why the steering (manual) was so strenuous with a fairly light load up front. Got off to look and the R/F tire was completely flat. Thankfully I didn't roll a bead and was close enough to the garage to air it back up with the shop air. Bit I also learned a valuable lesson that day check the tire pressure before you get too far from the garage. I still don't know what caused that tire to be low...
6,275
it's a physics thing.....air molecules ( O2, N, AR, etc....) 'escapes' through the rubber tire
the big problem is that with less air pressure, sidewall flex way beyond 'design limits'. do this a few times and cracks form, and more air escapes....see this on riders all the time.
every time it happens here, tire gets a tube..end of 'leaky air' problems
MAArcher
Kubota B8200
Oct 6, 2022
116
47
New England
If you have cordless tools, check and see if they make an inflator. I have Royobi stuff and got this earlier this year when they were having a buy one tool get one tool free sale:
Works good and now I don't have to run a hundred yards of hose to fill all the tires around the yard. Its not real fast but you just hook it up, set the pressure, go do something else for a minute and let it fill. Shuts off automatically.
trial and error
Feb 16, 2023
394
386
NY
Thank you, I have the ridgid one and use it a lot. That situation called for shop air I was in a hurry and even with the weight off the front end the cordless wasn't cutting it. I use the ridgid one for checking and toping off the tires on the car, truck trailer etc. In that particular situation firing up the shop compressor was worth the effort a d faster . It's amazing how long an inflator can take to air up a flat 6-12 r1 ag tire from flat lol
5,163
My tire inflator is a 25-year-old Quincy with an 80-gallon tank. It has never failed me, and it is one of the best purchases that I made in my adult life. Thinking about it, it might even be more than 25 years old. Will have to check the date plate on the tank for the year of manufacture. I also have a Quincy upright 60-gallon tank that I bought for $100 because it fell over when it was delivered and the starter box was destroyed. There was a 3-phase motor on the unit, and I found a new Baldor 5 HP single-phase motor and mounted it, but never got around to finishing the electrical hook-up. It is on my list of things to do before I pass.
The Evil Twin
L2501, LA526,
Jul 19, 2022
3,212
3,563
This type of situation is exactly why I keep a nitrogen cylinder in the RV. It's parked at home, so always there when I need it- on the road or on the farmette.
Lencho
B7100hst
Jan 21, 2017
451
121
NM
Good post Yooper. A similar thing happened to me when I had my tractor at my wife’s aunt’s house repairing a retaining wall. Low pressure in the right rear tire and all the ballast leaked out as well. PITA to pull the tire, take it home and refill with ballast and get the bead reseated.
Trimley
Jul 25, 2023
1,181
872
PNW-WA
Hey, you had the Box Blade on, that made it a lot easier than without!!
Yooper
3901 LA525
May 31, 2015
1,733
910
NE Wisconsin
A follow up note here. That Rim Guard stuff is like a dark syrup and it stained the concrete where I fixed the tire.
GrizBota
Apr 26, 2023
1,147
733
Oregon
Hmm not sure what difference having the box blade on does?
Probably mistaken about the 3 point hitch having down pressure. Wouldn’t that be nice.
5,187
I have a 33 year old Quincy, 5HP Baldor, two stage, 175 psi, 20cfm, (pressure lubed), 80 gal upright..
Bought it new!
Agreed.....one of my best purchases ever!
I also have a little portable Quincy (1-1/2 HP?) belt drive, on a 20 gal. tank.
Lencho
B7100hst
Jan 21, 2017
451
121
NM
Brain fart. The 3PH has no downforce. I was thinking of the landing gear on the backhoe.
The photo may look like the box blade is supporting the axle. I have a jack under the center tow hitch. Hard to see it in the photo.
leveraddict
Apr 1, 2019
905
594
NEPA
When you post a photo you should have the choice to post a full size image. Your pics are very small.
