Hi all, great forum.
A little background, this is the easiest starting engine I have ever had. At least in the summer. Not so in the winter.
After last snow had a hard time starting, temps in 20's not that bad, so decided to dig into glow plugs. I have a shop manual, how hard can it be.
First thing I did was check voltage at glow plug, which the manual says nothing about doing. I only had 7v so tore everything apart and checked by book.
Starter switch checked good, wiring good, glow plugs .8 ohm, spec is .5 which should be good. Not finding anything and in this far, I decided to get new gp from Kubota.
Installed new plugs and still don't think it's right, I have 12.8 v at power wire at GP.
Hook to GP and drops to 8.1 on preheat and 8.7 on start. Battery holding 12.8 steady.
Glow plugs are pulling 28 amps.
I did a few timed 45sec preheats and didn't see or feel anything at the GP indicator nor did I feel any heat from GP tips. Does anyone know if this is normal. I haven't tried starting it yet, as I still have the intake off. Don't see it being any different.
Has anyone ever checked the voltage at the GP or know what it should be.
Even though the switch ohm out good, could I still be losing voltage there.
Thanks Tim
Thanks Tim
