Wow, epic fail ... Unless the point was to spend as much money as possible to make your forks carry that log equally well as spending no extra money, then ... well doneGrapple forks, the solution
Great point......said NO ONE ever before this post.
Thanks.Great point.
As an experienced operator of fork lifts, professionally, and as a bucket - skip loader operator, professionally, I think that the grapple has a long way to go to get to where it should be.
Yes Sir. I think it comes down to efficiency with an implement. Or if you're just having fun, playing around. Tractor therapy is valid in both situations.Thanks.
As an experienced tax preparer whose sat behind a desk his whole life, professionally, never ever drove a fork lift, or a bucket, I think you're totally wrong about the grapple, it's the most fun I've ever had with my pants on.
Efficiency is huge.Yes Sir. I think it comes down to efficiency with an implement. Or if you're just having fun, playing around. Tractor therapy is valid in both situations.
If you need to get things done efficiently, do it as efficiently as possible. If you just like playing with fun toys, that's what you do.
To use your last sentence... A couple trying to raise a family are dedicated to a goal of having children.
Someone just having fun with a lover and just getting thier rocks off is something completely different.
Your goal of having fun is completely different than my goal of getting a project done as quickly and efficiently as possible.
Both points valid. One carries more weight to each of us differently.
I appreciate and respect your post. I just have a different goal. Efficiency.
To me, it's not about having fun, it's about getting things accomplished as expediently as possible.
then use the grapple...it's about getting things accomplished as expediently as possible.
I am not very experienced, but I love this "pallet-fork add-grapple". I find that the grapple sometimes goes on and off during the same day, so there are still lots of "fork is better" applications. The grapple is unbeatable for big mouthfuls of brush or unbalanced loads of logs. Also when the surroundings don't allow me to get square on to the middle of a longer log I can grip it at an angle or off-center.Not yanking anyone's chain, Except my own literal chain when I secure 3 times the load of cut branches on my forks vs using the grapple.
I just wanted to learn by hearing everyone's input.
I think that the biggest issue with my grapple is that the lower tines are too short. I have to come down from above to grab a load.
We used to lay out a chain before cutting branches. Center laying the branches over the chain. Then bring in the loader with forks if available and drive it under the pile, careful not to hit the chain.
Then lift the loader a foot, and pull the chain up and around the load of branches...
Beat the snot out of ANY grapple grab I've ever seen.
Even as awkward as I am, I can get more done by staying in the seat and making additional trip(s). If I have to hop out to cinch down the chain and then hop back up to move the load I'm achier at the end of the day and probably didn't get as much done. I can compress the pile before and during the pickup, using the grapple, from the seat of the tractor....
Have to agree Bob, if I make more trips vs on and off I'm OK with that.Even as awkward as I am, I can get more done by staying in the seat and making additional trip(s). If I have to hop out to cinch down the chain and then hop back up to move the load I'm achier at the end of the day and probably didn't get as much done. I can compress the pile before and during the pickup, using the grapple, from the seat of the tractor.
Geno Auriemma, the Hall of Fame UConn Women's Basketball coach, has a similar mantra, "We don't practice until we get it right, we practice until we don't get it wrong".. . .
We've been taught since young, "Practice makes perfect." That's not necessarily true. PERFECT PRACTICE MAKES PERFECT. When one does something wrong repeatedly they get good at doing it wrong.
did you mod the grapple with some kind of netting to make that leaf situation? This set up would transform my life---leaves are killing me.disagree.
can you pick up leaves with forks?
chicks dont smile when you make them use forks, they want grapples.
