Hi folks, I shared a post a few months ago, but I didn't close on that home. Now, I'm closing on a different property here in SWPA.
5 acres. Former farmland, house built ~2 years ago. ~450ft sloped gravel driveway (which i think i will need to remove the stone and use more of a crusher run/2a setup). Mostly pasture mix grass, some kind of fencing around the property.
Main item - front towards the road is pretty sloped with a ditch at the bottom.
For the departing owners - they used once piece of equipment for grass - an MX5100 w/ a 72" brush hog (on turf tires). Snow was handled with a separate snow blower.
My rough plan -
Zero turn mower - most of the yard , mostly due to speed. 60"+ would be my plan. That nixes a MMM.
I'm sure I need a tractor for around the property, front blade for snow, helping to prepare for a garage build, etc. I dont' know about the brush hog for the rear.
My questions:
The hill stability scares me a bit. I can see overall weight, and width on the Kubota site. I can add spacers to most tractors. However, I can't mentally figure out Center of Gravity improvements/changes. I know tire/wheel choice can impact that. Any series better or worse for that? Somewhere between LX and MX?
Tires - I think turf tires are usually smaller diameter, but I'd probably go towards an R4/R14 with snow use. Am I on the right path there?
So....is an LX2610/3310 probably enough? That's the model I've researched the most and seemed to be a decent fit for hobby use / 5 acres / snow duty. My worry about overbuying is decreased stability. I know there is no right answer, but just trying to have a favorite (that may get swayed by availability).
Thanks!
-Rick
My rough plan -
My questions:
Thanks!
-Rick
