Does anyone have a solid list of parts including fluids and quantities needed to do a complete 50 hour service? I want to do a full fluid/filter change. I started compiling a list but if someone has already has one please share. Thank You
Same here, 45 hours and wouldn't hurt to hear from the professionals with over 50 hours.Subscribed.
Need to do mine too.
Will be going to my local dealer for parts/supplies.
My manual says HST filter only at 50hrs as well, but I went with the WSM, which says both filter and screen cleaning with fluid change.Unless I'm seeing it wrong my manual shows just a filter change at 50 hours on hydraulics. Is this right? Dealer said at one time he would wait till a 100 hours. View attachment 64673
This was my list for my 50hr service:Maybe I should of been more clear on the original post. I don't want to debate what manual is correct or what dealer is correct. I am just going to do it overkill and be done. It really isn't a ton of money.
Assuming full service (all HST/Engine Oil/front Axle Oil/All filters. What are the OEM part #'s and fluid quantities needed? I just want everything in my garage so I can spend a couple of hours going through it without needing to go back to the dealer.
Thanks
Thanks!This was my list for my 50hr service:
HH150-32430 OIL FILTER
HHK20-26990 HYDRAULIC FILTER
K1211-82320 AIR FILTER
12581-43012 X 2 FUEL FILTERS
70000-10001 15W-40 MOTOR OIL
70000-4202 SUPER UDT2 2.5 GAL HYDRAULIC OIL
70000-40201 SUPER UDT 1 GAL HYDRAULIC OIL ( TO TOP OFF COMPLETE TRANS SERVICE AND EXTRA ON SHELF)
MY COST AT DEALER WAS JUST OVER $150 FOR THIS COMPLETE LIST.
BTT.
only threw one quart of Super UDT 2 at me saying, you won't lose that much if your quick with your hands.
We'll see how this goes....
I was wondering how fast it would gush out (being a new F150 owner (they'll get the joke))Crack the old filter - which can be fun ........... then have the new ALREADY lubed around the gasket....
have the new one close by - spin off old as quick as possible, there will be no gush of oil, but it will come out a bit, then spin the new one on. I bet you loose less than a solo cup!!!!
Do you go by owners manual or WSM? WSM shows more things that have to be changed out like hydro fluid.Unless I'm seeing it wrong my manual shows just a filter change at 50 hours on hydraulics. Is this right? Dealer said at one time he would wait till a 100 hours. View attachment 64673
