I recently repowered a Cletrac HG with a Kubota 1105 engine out of a Jacobsen mower. I swapped out the hydrostatic flywheel for a flywheel that used the stock Kubota clutch since the tractor has a manual transmission. When driving the crawler tractor down a 40% slope the fuel increases on its own. I rigged up a control lever to the manual shutoff on the IP and if I manually restrict fuel at the IP when going down slope it will idle and run at a normal speed. Based on this I am assuming the governor is somehow increasing fuel flow when on a steep slope. Any thoughts or suggestions on how to rectify this issue would be greatly appreciated.
