I am still trying to get all the figures together, but, I dont see any "lifting" benefits between clamp on bucket forks and dedicated QA forks. If the BX23s has 1,000lb (rounded) lift at the pin (no bucket), then you add a 120lb bucket on a QA, you get 500lb lift at 48" according to TTwTim. A dedicated QA fork setup is min 160lbs (QA attachment and forks all ready to go). So, I would be losing 40lbs of lift from the start, which gives me 460lb of lift (averaged out). From there, the math starts kicking in. I believe there is a general rule you lose so much lift beyond the pin at certain inches the further out you go. I cant find that info again and give up, lol. But, from what I HAVE read, I think the two setups are neck and neck for lift capacity. I have an extra blade on my bucket now so I dont think I will be getting a smiley face on it any time soon with 400lbs on the end of a set of clamp on's. Other than that, I dont see any advantages with lift, other than paying an extra $400.
Am I missing anything in my mathematical euphoria, lol?
