Bought one this fall to use in the spring.
I have several unreachable slopes that tax my body when I weed wack them.
So - this is for my BX-23S.
Here is my unboxing and connection info.
#1 - Stand the long narrow box UPRIGHT before opening. Trust me.
#2 - It's got an Open Center valve setup and hooks right to my BackHoe flat 1/4" face connections - hose adaptor from 1/2 to 1/4 required.
#3 - Ships no fluid. Have a quart or so handy to top the reservoir.
#4 - After easy-enough assembly double check all bolts and connections. Should probably use Lock Tite and tape for hydraulics. They did.
#5 - BX23S has plenty of volume to run the mower
#6 - Make sure you create a counter-weight for the base of the mower stand. I am in process of creating one this winter and will post pics on completion this spring. The weight of the attachment plus counterweight should be less than 1000 lbs as this is the 3pt hitch max.
#7 - Added Messick's 3pt Stabilizer bars because I'm afraid I'll break a turnbuckle and that would be a really bad thing when operating.
As I said I'll post again this spring when all is functional.
Wish me luck.
