Mowing lawn. Bucket on or off?
VT_Kubota
B2650
Dec 7, 2020
42
19
Vermont
vthomesource.com
I ordered a 5' Bush Hog finish mower for my B2650 in February. It was finally shipped out last week, so I should have it soon!
For those of you that have a bucket on your tractor and also use your tractor for mowing your lawn:
Do you (a) remove the entire loader, (b) remove the bucket only, or (c) keep the bucket and loader on the tractor when you mow your lawn?
I understand the benefits of less weight and easier maneuverability around buildings and objects with the entire loader off the tractor, but I'm just curious about what others usually do.
BAP
Dec 31, 2012
2,751
865
I mow with my B2920 with 60”mmm. I take my loader of when mowing to make tractor lighter and more maneuverable in tight places. It also rides better without the loader bouncing.
5,228
Like BAP, I mow without the loader for same reasons. My BX doesn't have a SSQA bucket.
If I had an SSQA bucket, I'd definitely try it with just the bucket off.
Goz63
Kubota L2501, LA525 loader, QH15,Land Pride RCR1860, BB2560, SGC0660, forks
Jun 19, 2021
299
349
Mississippi
I don’t use my rotary cutter for the lawn. I use a zero turn. I use the rotary cutter on the pasture. I leave the bucket on. I just lift it up to get tighter to fences etc. No issues.
johnjk
Apr 13, 2017
1,462
1,269
West Mansfield, OH
I leave my FEL on my B3200 when I brush hog with my Woods RC5. If I am in the fields, I can use my tooth bar to rip out saplings before they drag under the B so I don’t rip up anything and I’m not leaving sharp stumps to catch a tire on later. I also like having the ability to use the FEL as a possible extraction device. I’ve gotten in to areas that look ok but quickly get mired due to not having 4wd engaged or uneaven ground getting the B off balance. I love being able to use the bucket to help level and extract me from my stupidity
rkidd
Dec 7, 2015
743
67
Jefferson Ohio
I do the same as Bap and Rcw with my B2650 and 60" mmm. I take the loader completely off to be more manuerverable and definitely rides much better that way.
3,307
OFF I dont know about your ground but I find that with it off the machine is more maneuverable and less tippy feeling on the hills. Flat areas no worries plus you dont have to worry about hitting something you had not intended to with the bucket
SDT
multiple and various
Apr 15, 2018
3,255
1,041
SE, IN
Remove the entire FEL to increase maneuverability and reduce weight.
SDT
ItBmine
B2620, RTV-X1100C
Jan 21, 2014
1,375
378
Guess it would depend on your ground, but I mow with my loader on. Comes in handy every time I have to stop and pick tree limbs and branches up.
My lawns are hard ground so the weight doesn't hurt anything.
shelkol
bx-2200, Woods BH6000 backhoe, Tach-N-Go quick attach bucket, snow blower
Nov 12, 2015
195
160
Westford, Massachusetts
shelkol.com
I leave the loader arms on but take the bucket off. Less work to just remove the bucket and still somewhat maneuverable.
Crash277
BX23S
Jan 17, 2021
846
622
thats what i have started doing as well. mostly because my yard is wet and even just walking on some parts leaves footprints.. so the less weight the better.
i7win7
Feb 21, 2020
3,379
3,982
Central, IL
BX w/mmm, I leave bucket on. Small front wheels & extra weight makes finding potholes in lawn easy. When butt returns to seat, shut off mower deck, drive over to your "spare dirt" pile and scoop up some fill material. After dumping and smoothing with bucket, re-engage mower and search for next pothole.
orange crusher
BX 2680
Sep 30, 2017
356
480
ontario canada
Sounds like you completed municipal public works training at some point.......LOL
S-G-R
LX3310
Jun 17, 2020
1,115
2,261
PEI Canada
I have never had the loader off in a year but do remove the bucket when I mow.
dlsmith
BX2230, LA211
Nov 15, 2018
1,235
789
Goshen, IN
I only ever took the loader off my BX once, just to see how it was done. I leave it on for mowing, as it's really handy to stop and trim trees with low hanging branches and toss them in the bucket. Comes in handy when picking up trash along the road opposite the house when I mow that area. Effing litterbugs tick me off. :devilish:
michigander
547
234
Northern Michigan
Loader off , I've tried it with just bucket off for a few minutes.
Loader off so much faster moving around :)
Spring 2020 to spring 2021 I went a year with loader off lol
