So I recently acquired a barely used M5660SUH with loader and it fits my needs on everything but pulling a moldboard plow. I was in the market for a used M6060 or older m6800 or the like, but this one was too good of a deal to pass up. I knew this model lacked draft control, but for the price I figured I'd find a solution or just bump the position control when the machine bogged down. I assumed based on HP this machine should pull a 3 bottom plow fairly well and a 2 bottom handily. I have been struggling to get it to make a decent furrow with an old Dearborn 2-14" plow. Traction seems to be the issue, doesn't bog the engine, just starts slipping. I can't get it to stay in the furrow for more than 10' before it looses traction and I have to pull the plow out of the ground.
The rears are 70% full with methanol, I am looking into getting wheel weights ($$$). Do you think weight is my problem or is this a fools errand given that the machine lacks draft control? I don't want to sink another $1000 into wheel weights if its not gonna help and I ultimately have to sell the machine for something more suited to draft work. I don't have much experience with plowing with modern tractors, or frankly tractors without draft control. I could keep looking for a 6060 if draft control is ultimately the achilles heel to plowing with this machine, just thought I'd ask some folks with more experience than myself with the orange tractors.
Thanks
Thanks
