My positive battery cable post harness broke - it had an extra small red wired on it but I’ve not been able to back and figure out where that wire went or was supposed to go. I could not find a replacement so I just replaced with a single harness that just has the one large cable wire; Everything seems to work - the tractor overhears after a coup,e hours or hard bush hogging then won’t start for an hour, then starts right up once cool.
So my questions are: what is that extra wire and is it just incorporated into the main cable?
2. Is there a switch that prevents the tractor from starting til it cools to certain
Temperature?
Thank you!
Temperature?
Thank you!
