I am looking to replace my OEM front R4 tires on my BX25d tractor. The tread looks brand new on my 500hr tractor, rarely run on cement, mostly weeds/grass.
I have had a lot of problems with my tires, mostly the front tires.
I have tried checking pressure every usage.
Adding Inner-tubes which didn't work for long and finally some slime equivalent that cost me a bundle at the tire service.
I have several tire issues every year, and I am looking for something that's better than the factory tire.
I had good pressure this morning. Filled up my bucket with firewood and had to turn tight to back out and ended up with my tire coming off rim. I drove my car over to my shop to get my small pancake air compressor and try to fill it up. However I can tell the side wall is cracked and was loosing air. I am a little ticked I lost my slime stuff.
It's possible I messed up the sidewall (or even the rims) running it low before I started my every use tire pressure check fill-up. Also, the rubber bit / slime solution was working very good up till today. Lasted for about 8 months (roughly 30 hours during winter) and rarely had to put air in the tires.
I am ready for an upgrade and have been reading posts on replacement options, found a couple listed below. The amazon ones appear to be OEM or similar, and the ones on summit are much cheaper, so I am guessing they won't hold up. I read something about someone replacing them with skid steer tires that were much stiffer and more durable, but I am concerned about the ratios for 4wd.
Hoping someone would have some input here on some better tires, or a new tires / inner tube / slime solution. If I missed a good thread, please let me know!
https://www.amazon.com/MowerPartsGroup-Assemblies-18x8-50-10-Kubota-BX2350D/dp/B07XPGGWT6
https://www.summitracing.com/parts/CRR-570046
Thanks for any input!
