L1500 - Oil Drain Plug is Rounded and Stuck
Profnohair
L1500, 42" bh, box blade, G6200HST, Mahindra 450 with BH, FEL, etc.
I tried to change the oil in the L1500 today and besides having the wrong filter, the oil drain plug is rounded off and stuck tight. I tried to use vice grips to no avail. I cannot tell if the head of the bolt is screwed into the round 1/8" thick metal above it, or if the 1/8" is part of the bolt that screws into the oil pan itself. I can grip the 1/8" with a pipe wrench but I didn't want to turn it fearing it was part of the oil pan and would break off the weld.
Can one of you Kabota seasoned guys let me know if I am safe gripping the 1/8" piece and turning it.
Also, I found on this site what I thought was the correct part number for the canister oil filter (NAPA 51302). I purchased it and found that this filter is about an inch too long for the application. Does anyone know of a crossover number for the canister filter that can be purchased locally?
Thanks,
Profnohair
birddogger
433
Pittsburgh
I believe that little bit of lip is 1/2 washer, 1/2 plug.
These plugs are a sore point for me. Some people think they must be as tight as a lug nut or they'll fall out or something....
nevermind, I'll let it go at that.:rolleyes:
Good luck.
stepdoctor
L295DT, loader, backhoe, John Deere 40W, International 140
Jul 3, 2011
26
Troutville Virginia
If you have a welder, tack a piece of flat stock or a 3 inch bolt to the plug to give you some leverage to remove it.
Eric McCarthy
Kubota B6100E
Dec 21, 2009
5,223
Richmond Va
Word on the streets from Capatain Candle Wax, aka Aquaforce. Heat the nut up with a torce and jam a wax candle on it and you should be able to turn the nut loose freely by hand!
E/S
2009 M8540HDC 4x4 w/ Cab
Jan 6, 2010
251
Reno, NV
If all else fails I have used a cold chisel and Carefully used it to brake it loose.
E/S
Profnohair
I thought about heat but never knew about the candlewax. I will give it a try and report back. It may be a while before I get back to trying.
Profnohair
Correct canister filter is NAPA# 7030, or Kubota part # 15108-32080.
Not sure were that other incorrect part number came from, let me know so I can edit the post and clean that error up.
It is not in a post, it is in an article. On the left side of the article section, it has a section called "Part Numbers - Oil Filters".
Under L1500 it states the following apparently incorrect (at least on my L1500 which has a canister filter) filter numbers:
L1500 750 15213-32090 1342 B178 51342 PH2870A
Thanks for maintaining a great site.
Good thing you don't charge by the hour to use the site. I would be broke with the time I spend on here since obtaining my Kubota.
Profnohair
Eric McCarthy
Kubota B6100E
Dec 21, 2009
5,223
Richmond Va
Another member Aquaforce had mentioned a while back that if you heat the aera with a torch, even a simple propaine torch and jam a wax candle on there it should loosen up freely by hand. Other members tried his trick and raved how well it worked.
So accordingly we nick named him Captain Candle Wax!
Profnohair
I am going to try this as soon as I get the the correct cannister oil filter in my hands for which I now have the correct part number.
Will report back if he is worthy of the title or not.
Dennis
79
Queensland Australia
I don't get it. What is the purpose of the wax?
Eric McCarthy
Kubota B6100E
Dec 21, 2009
5,223
Richmond Va
The hot wax works itself down into the threads creating a slick surface. Luberacation basically.
GWD
M7040, L48 TLB, BX2200
Jan 8, 2010
792
15
Northern California
Another option is to file down the bolt faces to the next smaller socket size. Sometimes a little can be taken off a metric to make it standard.
An impact wrench can be your friend as well although it is not recommended for general work.
It is even possible to file two sides flat and use a spanner wrench.
A friend with a welder could really be a help. Welding a new nut on the end of the damaged bolt is easy and works every time. A professional could do it but might be a bit pricey. No harm in asking a pro what the charge might be.
Profnohair
Profnohair
My neighbor of the land has volunteered to weld a bolt to it as soon as I am able to get it to him. Unfortunately, I don't know when I will be able to get it to him as I have to round up a trailer and he is 45 miles away. I am more concerned with getting my son moved onto the land. (Building pump house, getting treatment plant up and running, etc.)
I am going to try the heat and wax first though.
Profnohair
