IC 9-19-6-11 Farm equipment and tractors manufactured before July 1, 2006
Sec. 11. (a) This section does not apply to:
(1) an implement of husbandry; or
(2) a farm tractor;
manufactured after June 30, 2006.
(b) A farm tractor and a self-propelled farm equipment unit or an implement of agriculture designed to be operated primarily in a farm field or on farm premises, if operated on a highway and not equipped with an electric lighting system, must at all times required by IC 9-21-7-2 be equipped with the following:
(1) At least one (1) lamp displaying a white light visible from a distance of not less than five hundred (500) feet to the front of the vehicle.
(2) At least one (1) lamp displaying a red light visible from a distance of not less than five hundred (500) feet to the rear of the vehicle.
(3) Two (2) red reflectors visible from a distance of one hundred (100) feet to six hundred (600) feet to the rear when illuminated by the upper beams of head lamps.
The lights required by this subsection must be positioned so that one (1) lamp showing to the front and one (1) lamp or reflector showing to the rear will indicate the furthest projection of the tractor, unit, or implement on the side of the road used in passing the vehicle.
(c) A combination of farm tractor and towed unit of farm equipment or implement of agriculture designed to be operated primarily in a farm field or on farm premises, if operated on a highway and not equipped with an electric lighting system, must at all times required by IC 9-21-7-2 be equipped with two (2) red reflectors that meet the following requirements:
(1) Are visible from a distance of one hundred (100) feet to six hundred (600) feet to the rear when illuminated by the upper beams of head lamps.
(2) Are mounted in a manner so as to indicate as nearly as practicable the extreme left and right rear projections of the towed unit or implement on the highway.
(d) A farm tractor and a self-propelled unit of farm equipment or an implement of agriculture designed to be operated primarily in a farm field or on farm premises, if operated on a highway and equipped with an electric lighting system, must at all times required by IC 9-21-7-2 be equipped with the following:
(1) Two (2) single-beam or multiple-beam head lamps meeting the requirements of section 20 or 21 of this chapter or IC 9-21-7-9.
(2) Two (2) red lamps visible from a distance of not less than five hundred (500) feet to the rear, or in the alternative one (1) red lamp visible from a distance of not less than five hundred (500) feet to the rear and two (2) red reflectors visible from a distance of one hundred (100) feet to six hundred (600) feet to the rear when illuminated by the upper beams of head lamps.
The red lamps or reflectors must be mounted in the rear of the farm
tractor or self-propelled implement of agriculture so as to indicate as nearly as practicable the extreme left and right projections of the vehicle on the highways.
(e) A combination of farm tractor and towed farm equipment or towed implement of agriculture designed to be operated primarily in a farm field or on farm premises, if operated on a highway and equipped with an electric lighting system, must at all times required by IC 9-21-7-2 be equipped as follows:
(1) The farm tractor element of each combination must be equipped with two (2) single-beam or multiple-beam head lamps meeting the requirements of section 20 or 21 of this chapter or IC 9-21-7-9.
(2) The towed unit of farm equipment or implement of agriculture element of each combination must be equipped with the following:
(A) Two (2) red lamps visible from a distance of not less than five hundred (500) feet to the rear, or as an alternative one (1) red lamp visible from a distance of not less than five hundred (500) feet to the rear.
(B) Two (2) red reflectors visible from a distance of one hundred (100) feet to six hundred (600) feet to the rear when illuminated by the upper beams of head lamps.
The red lamps or reflectors must be located so as to indicate as nearly as practicable the extreme left and right rear projections of the towed unit or implement on the highway.
(3) A combination of farm tractor and towed farm equipment or towed implement of agriculture equipped with an electric lighting system must be equipped with the following:
(A) A lamp displaying a white or an amber light, or any shade of color between white and amber visible from a distance of not less than five hundred (500) feet to the front.
(B) A lamp displaying a red light visible from a distance of not less than five hundred (500) feet to the rear.
The lamps must be installed or capable of being positioned so as to indicate to the front and rear the furthest projection of that combination on the side of the road used by other vehicles in passing that combination.
(f) A farm tractor, a self-propelled farm equipment unit, or an implement of agriculture must not display blinding field or flood lights when operated on a highway.
(g) All rear lighting requirements may be satisfied by having a vehicle with flashing lights immediately trail farm equipment in accordance with IC 9-21-7-11.
As added by P.L.2-1991, SEC.7. Amended by P.L.1-1991, SEC.91; P.L.127-1995, SEC.1; P.L.148-2005, SEC.1; P.L.210-2005, SEC.29; P.L.1-2006, SEC.161.
IC 9-19-6-11.3
Implements of husbandry and farm tractors; required equipment when manufactured after June 30, 2006, and operated on a
highway
Sec. 11.3. (a) This section applies to the following items manufactured after June 30, 2006, when operated on a highway:
(1) An implement of husbandry.
(2) A farm tractor.
(b) An implement of husbandry or a farm tractor listed in subsection (a) must be equipped with:
(1) head lamps;
(2) tail lamps;
(3) work lamps;
(4) warning lamps;
(5) extremity lamps;
(6) turn indicators;
(7) rear reflectors;
(8) front and rear conspicuity material; and
(9) front, rear, and side retroreflective material;
that comply with the standards contained in the American Society of Agricultural Engineers (ASAE) Standard S279.11 DEC01 or any subsequent standards developed by ASAE at the time the vehicle was manufactured.
As added by P.L.148-2005, SEC.2.
