For Sale FEL Gear Pump w/coupler - Kubota L245DT
1,415
This person may be interested if you can connect with them
Tractor L245 2WD
Loader L1730 (Best I can tell)
Flex Shaft Part # 70050-00705 .
So the Flex Shaft that drives the front mounted hydraulic pump for the loader has ripped in half. The dealer said this part is no longer available and I haven't had luck finding a used one as of yet. If anyone has some experience with this issue I'd love some advice. In the perfect world I'd like to find a new or used working part (where can I look?). If that's not an option, what else can I do? Thanks for any help.
Also, why is this a flex shaft? is there really that much movement between the components that a rigid shaft would not work?
TractorBill
L245DT W/Loader L1700
Aug 28, 2010
20
Milford, NJ, USA
Yes, the shaft is no longer available. The shaft on the engine side is worn out.
Had to run my FEL off the rear hydraulics.
Which half of the shaft needs replacing?
I've also included some more pics of shaft showing were it is worn.
sullpond
L245DT
Jun 24, 2009
14
I'd like to get it, if no one else is ahead of me. If you can PM me we can set up shipping etc...
Tim
