Show me your Refueling Setup
Flienlow
Kubota BX25D, Kubota U25 mini EX, SVL75,Landpride Grapple,Landpride grading scra
Mar 9, 2015
352
snohomish
It appears that I am rapidly out growing my 6 gal VPS fuel jug. To be honest, I had no idea how much fuel my U25 would use, and thought it would fall with in the range of the BX25 a little where you refuel every couple of days or so. That is not the case, and I could easily refuel this machine twice a day given the work load. That coupled by the BX, it is time for me to consider semi-Bulk fuel import. My Neighbor (with all his fanciness,) has a really nice truck mounted fuel unit, However, I don't need to drag fuel to my office and on Costco runs with the family. I also don't want to lose my bed cover on the truck. At this point, I am thinking about buying a 55gal barrel and putting a hand pump on it, But would like to see what others are doing for ideas.
countrynerd
BX25D, L3301
Jun 6, 2016
119
thumb, MI, USA
50 gallon TSC square tank with hand rotary pump. That is for BX... But use BX for power generator if power out so in winter can last two days without going for more fuel during storm
coachgeo
Nov 16, 2012
2,459
37
Southern OH
5 Gal military fuel can. Lift it up onto hood. Supergiggler Fuel line to transfer fuel. The secret is to plan ahead and have a thing or three to do while it transfers fuel. Oh and another secret is to keep checking fuel level.
One thing I like about them is junk in your fuel storage tank.... stays there.
New ones are faster though and I see now there is a bigger one available for even faster transfer
TexasBoy
Kubota M7060 HDC12 & L4600DT
Dec 11, 2013
117
10
Central Texas
I built a sturdy pallet from treated material and mounted a transfer tank on it. Makes it easy to put on the back of my truck to run into town and refill with red dye Ag diesel. Bought a Fill-Rite 15gpm pump, plumbed in sediment/water filters both and put a long cord on it that plugs into the Kubota when I need to refuel. Works great and no more stinkin' gas jugs.
Reactions: 6 users
Flienlow
Mar 9, 2015
352
snohomish
This is why I make stupid posts. That is a nice Setup!
gk527
Kubota B2650
Apr 6, 2017
140
Central Kentucky
I know this thread is about refueling, but this post about using his BX for a power generator has me interested. How are you doing this?
I'm in the process of building a house and have been going back and forth on prewiring for a generator.
Flienlow
Mar 9, 2015
352
snohomish
Probably a PTO generator.
http://www.northerntool.com/shop/tools/category_generators+pto-generators
Pros: if you use your tractor, you know it will always start, and will be maintained and you wont need to keep up a Generator.
Cons: It will rack up your engine hours just to make energy
A small BX will work, but doesn't have enough output for most PTO generator Max outputs.
gk527
Kubota B2650
Apr 6, 2017
140
Central Kentucky
I google'd this after I asked. I wasn't aware PTO generators existed. I've got a B2650 that's rated at 19HP at the PTO.
For someone like me where the power might go out once a year due to ice for a day or so, the PTO generator might be ideal for me. If I was in an area where power went out every time it snowed, then a dedicated diesel generator would be better.
John T
2017 BX23S 385XP Miller211 1952 Panhead Orange Ludwig 4 piece
May 5, 2017
1,299
817
under a rock
OK
Just a wild idea so don't blast me too hard....
I've got a 165 gal. home heating oil tank for the garage furnace.... 165 lasts about 2 seasons.. so I always have plenty to spare....
anyone run home heating oil or off road diesel in their Kub?
Or should I stick to ULSD?
I HAVE run it in my powerstroke diesel with no problems.... not often.... just a few times to test it....
no prob. but I run external canister filters on the P. stroke... pre/post pump.
Flienlow
Mar 9, 2015
352
snohomish
OK
I run off road diesel exclusively.
bxray
Bx25d
Dec 1, 2014
712
Cleveland, ohio
Off road should be the same as on road just with die to say no road tax was paid.
It would mark your filter and then you get a $10,000.00 fine.
7,631
John T, a few years ago when diesel was $4.50 or so, I noticed on Craig's List a guy had a tank of heating oil for sale. He was located on the edge of K.C, but had farmers all around him.
I gave him a call and asked what he had, what he wanted for it, and why he was selling it.
He had heating oil in a tank on the outside of his home. He had trouble with his furnace and could not find anyone to service it. He bought a new furnace and it was propane.
I brought three 55 gal. barrels and a 12v. pump. Paid him .90 a gallon and took it all. He asked me as, I was pumping, what I was going to do with it. When I told him using it in my tractors he had that look of bewilderment.
I did that one other time when fuel prices were crazy. That guy had 2 round tanks stacked in his basement. I pumped out the fuel and had to take the tanks. I got everything for my labor. Used the fuel, sold the tanks.
Some folks can't see past the label!!
countrynerd
BX25D, L3301
Jun 6, 2016
119
thumb, MI, USA
That is the one the ~$1000 one! Works great ran 3 days straight this last winter. Hours don't bother me tractors are made to work and diesel engines like running in my mind.
Also like that generator because is brushless motor. Last longer...
bearskinner
Sep 1, 2014
926
242
N. Idaho
I did more or less the same thing that TexasBoy did.
So do you guys get someone to come out to your ranch and fill those large tanks?
I was thinking about mounting a tank of diesel and one of gasoline on a trailer, just to have it more accessible ant to keep from going to town as much, just for more fuel
John T
May 5, 2017
1,299
817
under a rock
Good to know,
yeah I kinda figured it's all pretty much the same....
It's the "new" ultra low sulfur ONLY stickers they put on the new machines/trucks... that got me worried...
but I don't think my tractor would know the difference... It's more an EPA thing...
Sammy3700
Feb 20, 2012
463
Red Springs, NC
I am in NC not sure about summer vs winter grades other than reading on here. My friend that runs the local Exxon distribution office told me the only difference is what others said RED no road tax GREEN is taxed. They are both ultra low and either will work in a tractor.
