Hi Folks,
Long time lurker, first time posting.
I have an L1500 which is a little champion; a friend called him Wally and it stuck.
Use it mainly to slash a 5 acre block with a 4' Slasher; not quickly but we get the job done.
He's been running like a dream since I picked it up until the last time I tried to start it.
Cranks over fine with the decompression valve pulled, but very slowly with it engaged. Battery is new and was connected via jumper to a running diesel car engine so assume sufficient voltage.
I managed to get him started to move him out from undercover but had to push him back because for the life of me couldn't get him going.
Happened once before and simply tow started him and ran fine all day.
Bled the system, starting at the filter, than the banjo fitting at the pump, then up at the injectors. There wasn't a lot of fuel coming out of the injectors but there was fuel there so would have to expect the pump was working, and would certainly rule out fuel issues pre pump.
I'll have to take a multimeter out with me next time to check the voltage at the glow plugs but the indicator wire is heating up.
When i got it going the first time it was running perfectly without misbehaving at all.
Below there injector pump there is a sprung lever which I can not find any info on at all, when I turned it a nominal amount of water came out and then stopped; I assumed this might be a drain for a water separator?
Any suggestions here; perhaps starter motor U/S?
Would anyone have a service/repair manual they could share?
