I just changed the trans/hydraulic fluid in my L3010 and I used Kubota filters and UDT fluid, I now have a intermittent low squealing noise coming from under the tractor once in a while, getting more often as time goes on.Sometimes it's only at idle, sometimes when it's not doing it at idle ,if you it rev it up it starts and then bring it back down to an idle it will stop .Press the HST pedal and most times it goes away.And..sometimes it can sit running and not do it at all. Never had a peep of this noise until I did the fluid change, then I noticed it about a half hour of running it after the change. Air possibly?
