What model do I have?
9,116
Look down on the side of the transmission by the clutch pedal. Should be an I'd tag with a serial, and model numbers. If not there, check by the injection pump.
Can you get some better pics, the ones you posted are hard to see
mickeyd
Mar 21, 2014
1,192
Guin, AL
Welcome to the forum thorpboy. Not much to go on. Like Todd said, more pictures.
3,029
from those pictures.........
B6001?
Do what Daren said and report back
10,689
Yea a little hard to figure it out off a couple of pics the size of a postage stamp. ;)
Tomcat
B7000 4WD, RS1(?) rototiller, Konik 125 ATV
Nov 19, 2014
557
Thailand
Bigger pics and some info from the plate as per Daren.
7,514
Hey TC, I use to be able to post pictures, but I went and read that whole thread now I too confused to try!!
Tomcat
Nov 19, 2014
557
Thailand
Got me confused too. Right click the pic and select Open With Microsoft Office Picture Manager. Then, when your pic appears again - select edit pictures. On the right, select "resize". Then, on the right select "Predefined" touch the down arrow and scroll down to "Web Large". Works for me ;)
10,689
Little better, make it twice as big again.
How many cylinders does the engine have? 2 or 3?
3,029
Better picture.......
IF like Wolfman said -
Does it have 2 cyl or 3 cyl?
Does the pto spin CW or CCW?
B6000D has .6 L 2 cyl 13 HP and CWW pto
B6001DT has .7 L 3 cyl 14 HP and CW pto
which one you got?:)
10,689
On the side of the transmission where your left foot would sit, there should be some stamped #'s and usually the model # too. ;)
