Hi
I am the proud owner a Kubota B6000 which I have had for a few months now. Its one amazing little tractor - build like a tank. I'm sure the 'B' stands for "BEAST" as this little machine truly amazes me with what it can do.
Anyway I built a three point linkage crane for it (see attached photo) and now want to build a front end loader for it as well. The first process is identifying where I can get hydraulic power from. I've seen others connecting to the port underneath the seat (not sure where return goes though) but mine doesn't seem to have a valve just a 'plug' like the 'Iranian' models listed in the B6000 parts manual. I'd also like to use the 3 point linkage and loader at the same time so am not too keen on this option. I've also seen other B series tractors (B7100) and read on this forum (B61000) about using an integration block on the hydraulic lines running from the motor to the back end. unfortunately my tractor doesn't have the integration block and I'm wondering what exactly this is and does it have a part number?
I know the part number for the diverter block is 70070-00385 from previous posts but what is the part number for the integration block? Also what exactly are these blocks? are they anything special or can I simply just tap into these lines myself to get aux hydraulic power?
I realize the aux hydraulic power is limited due to the B6000's small hydraulic pump but it will be enough for my needs as I plan on using small dia. hydraulic rams.
I'm also sure others would be interested in adding some quick release hydraulic fittings on these lines to power various hydraulic implements as well. So if someone can shed some light on the integration block (how its works and what it is doing) and the diverter block it would be really useful.
Any advice or experience would be greatly appreciated.
Cheers John
Cheers John
