Sidekick
Jul 29, 2023
867
1,040
N.Y,
Can anyone recommend good quality 5/16" G70 chains? Looking to get some to use for the bucket and for logging. Amazon has 8 billion chains that are probably junk, I don't want junk.
I also made up a couple with the slide hooks like chokers for pulling logs and brush. Found a nice twisted clevis but only had a one inch pin so had to make a brass bushing for the draw bar to keep it from rattling
1,719
@Sidekick - do you recall what that red slide hook is properly named? The ones I have seen are not that closed so easily unhook until they are under some load. I can’t see any brand on the picture so not able to locate that style yet…
4,561
They’re a type of chain choker hook. It’s the style that came with the chain chokers supplied with my Farmi winch. They’re quite reliable for staying hooked, IME.
Kennyd4110
Vendor Member
Sep 7, 2013
1,315
601
Westminster, MD
www.boltonhooks.com
mdhughes
L3901DT
Dec 10, 2014
1,302
922
Ste Geneveive county, MO
Well, after the Paypal fiasco with BXpanded, I should’ve followed my gut.
But I got the Quick Connect Backhoe Bucket connector ordered, and it arrived in good time. This morning, I started what I figured would be maybe a 1 hour job to get it mounted. 8 hours later, it’s still not working as advertised. Many contact points had to be ground off, on the connector, on the BH77 backhoe dipper arm and on the mechanical thumb (OEM). I’ve gotta say, if I knew then what I know now, I would not have ordered this thing.
I put one on my BH77 when I first got it and I didn't have to do any grinding to get it installed and working. I also have the OEM mechanical thumb. Do you have any pictures of what you have done so far?
MotoBBQ
L3902 w/ LA526 loader; rotary cutter; box blade
Jun 26, 2023
MN
Finally woke the beast from the winter slumber. Used it to move some dirt piles. Made two bigger bumps into three smaller ones. Braapp!
Side note, 65hrs and still no regen. Love this thing, sips fuel. Maybe it's defective, but fuel gauge said "full" even after 3 hrs today.
Reactions: 9 users
8,124
That project turned out well. Looks great!
Thanks! These photos show how the D-ring and stop work on the drawbar. Now I have four good locations for chains and binders.
Reactions: 7 users
8,124
What was supposed to be a 3-hour discing job today turned into a 6-hour job. The property owner is very pleased with how it turned out, but more importantly, his Highland Heifers (the inspectors) are pleased, and all the work is to give them more pasture. They'll be bred this summer so will have calves next spring and he wants to make sure they have plenty of grazing. He wants me to come back next year and disc up another 3 acres. He has a New Holland 3037 or something that came with the property and he's going to borrow a drag harrow from a neighbor and smooth the field out prior to seeding.
The M6060 and Schafer disc did great and the six coulters worked out really well. The objective is to chop up the top 8" or so and the disc did just that. I made overlapping passes and then a variety of crossing passes. Speaking of the disc, I'll weld stops each side of the coulter mounting brackets since a couple moved sideways on the 3"x3"x3/8" tubing. All six coulters maintained the elevation setting, but lateral loading in the turns did move a couple of brackets an inch or so. An easy fix though.
There are some steep sections in this field but no trouble at all for the tractor. And finally a use for those SMV signs! 😂
Reactions: 11 users
GrumpyFarmer
3,584
Oh my tell me that is a ‘Ruby Red’.
(My Ruby is starting to suffer from the bubbling around the hemmed edges😒)
Is there any particular reason for dual triangles? Rule regulation or to match dual rear wheels on the tow vehicle?😂 (she’s a beaut👍)
I wish I could get into our plots but it’s just too wet. Maybe by the weekend😉
BBFarmer
Jul 12, 2024
251
455
Terry, MS
Loving that pic with her all loaded up behind the 450. That's desktop worthy right there.
How'd it feel going down the road?
8,124
Ford calls it Rapid Red. I was ambivalent about the color but it has really grown on me. If ordering a truck I would have played it safe and chosen silver, grey or dark green, but the red is striking for sure.
No reason for using both triangles other than one came off each tractor so I have two laying around.
8,124
Honestly, the truck was awesome but the gooseneck trailer can't get here soon enough. With long loads there are no options to position the load properly and I felt that the trailer was tongue heavy. The power of the F-450 and the 10-speed transmission, as well as all the bells and whistles such as backup, side and front cameras make for an excellent driving experience. The truck is far exceeding my expectations at this point.
I was surprised to notice that the entire 12" center display automatically switches to a camera view when making a turn, the side of the truck on the inside of the turn to be more specific. This is my first time towing with this truck so I hadn't seen that feature yet. This is also the first time I've had a working backup camera on a truck to help align the trailer coupler and ball hitch, and that feature is a plus for sure.
BBFarmer
Jul 12, 2024
251
455
Terry, MS
She did look like she was up just barely in the front. Ever so slightly. Hard to tell on a 450 though.
That's amazing. I had no idea they did that. How handy.
BBFarmer
Jul 12, 2024
251
455
Terry, MS
Got the berries all cut and lookin fresh. The bushes are way full. Here's the ole girl up against our back wall of rabbiteyes. All over 8 feet tall.
And because of my questionable pruning techniques, we have some so full they're touching the ground
First harvest for the southern highbushes should be in 20-25 days. Then the rabbiteyes will follow into mid and late June.
Then I headed off out front to cut up by the road.
I was in a pretty good mood until I got up there and saw how much garbage useless individuals have been throwing out on me. Dang near half a buckets worth. What in the actual hell is wrong with folks. I never had this mentality even as a kid. You get where you need to go and then throw your crap away, not while going down the road.
The same people that do this are the same ones that would become extremely confrontational if they saw you throwing crap into their front yard. Whatever, I'll always continue to pick up after these less contributors to society.
Atleast we're all cleaned and cut and lookin good.
edkajo
1996 B1700
May 5, 2025
You have my respect.
I fully understand your trash frustration. We have the same issue with the few hundred feet of frontage.
I used to clean and cut it even though the state should be doing it.
Endless battle. Nothing is ever done to people who toss trash out of their cars and when we pick up, there's always more tossed the next day . So we got tired of it and finally gave up last year.
Especially when we started getting urine filled bottles.
Let them look at the litter every day that wasn't good enough to be in their car.
Maybe they'll start complaining about the mess the roadsides around here are.
BBFarmer
Jul 12, 2024
251
455
Terry, MS
It is definitely an endless battle. And unfortunately they never quit.
This is why "their" sides of town always tend to look the way they do.....atleast in my parts.
