Siesta Sundance
Oct 23, 2022
1,827
2,537
youtube.com
I fired up the M6060 this afternoon, headed down the lower driveway and attempted to push the snow over the edge. To be honest, it's not working quite the way I had hoped. I'm thinking about making up an extension of some sort to add to the left side of the rear blade to give me a couple feet more reach. I think that would do the trick.
Not sure if an offset hitch or arm would work, but definitely something worth looking into.
Moose7060
Oct 14, 2023
827
2,243
bc
Well, you are looking for a new truck to tow with!
Reactions: 6 users
g_man
Feb 3, 2023
279
1,289
NE Vermont
I know I said that I wouldn't post more of the same photos, but it was so nice this morning with the sun shining and a toasty 5°F out. You can see how the snow builds up along that outer edge of the lower driveway so I'll run down with the M6060 and rear blade later today (currently on block heater) and try to push the snow over the edge without rolling the tractor!
Nothing wrong with new pictures even if they look the same. I enjoy them. Ever think of a wing or offset rear blade to send the snow down over the edge ??
gg
9,401
gg
Thanks!
The rear blade is a three-way hydraulic offset, tilt and angle model. With the blade swung all the way over to the left and angled to reduce how much snow piles up down the center of the driveway, I don't have enough reach to push all the snow over. It's a precarious situation because the snow makes it near impossible to see where the ground is solid vs. not, and I don't want to roll the tractor.
Perhaps I'll clamp a section of 3/4" plywood to the blade as a test run and then look into making up a bolt-on steel piece that I'd keep on the blade during the winter.
MOOTS
MX6000
Jun 27, 2019
2,186
2,713
Canton, Georgia
I wore shorts to work today. And will do the same tomorrow.
WAS BANNED FOR NSFW PICS
5,154
Took the plow blade off and put the snowblower on. Weather people keep changing the way the "storm" is going to be, and the latest report is not much snow and rain on top of the white stuff. That means that the plow will have to be reinstalled in the morning. I need a second tractor so I can have both the plow and the snowblower ready to go without doing any additional work.
9,401
Now you're talking. :giggle:
9,401
Another 3" of snow overnight so more seat time in the MX this morning.
I have an idea for the rear Buhler blade on the M6060. I disconnected the cylinder that controls swing and am able to swing the blade way more to one side. If I can weld up an extension to go from the end of the cylinder rod to the attachment point on the boom, it would very likely move the blade over by a fair amount and might allow me to push all of the snow off the edge. I'll report back when I get to this today or tomorrow.
5,183
Our little private road needed some attention. Wheel tracks were worn in just enough to create a little berm between the wheel tracks and ditches, which is often the beginning of decline of gravel roads. There was plenty of gravel at the edges of the road so I decided to break out the old Leinbach backblade that’s older than I am (that’s old) to windrow gravel back toward the center of the road. Yes, I can pull it back to center with the boxblade but the backblade works better.
The blade is really too narrow for the L. It was a better fit for Dad’s 9N. But it’s in the shed and I use it so rarely, no chance I’m upgrading. The blade has been centered on the mount for at least 50 years. A couple months ago, I walked past it thinking it would be nice to have a blade that would offset and noticed the blade DOES offset. Not very convenient as you have to remove 5 bolts and bolt it back up in a different set of holes. Decided next time I used it, I was going to give the offset a whirl, and today was the day.
I had 5 good size bolts to remove which had at least 50 years, probably more like 60 years, to rust together. I also had a Milwaukee M18 Fuel high torque impact I picked up a while back. I’ve used it, but not on a challenge like this. Figured Kroil and heat would be involved. Wrong. The Milwaukee took them off and put them back easy peasy, although a couple were more than a little warm by the time they came off. I don’t think my old Chicago Pneumatic would have had a chance against all that rust.
It looks large and way offset in the first pic. That’s a perspective trick. Total width centered almost covers the tires but not quite.
Swung one pinhole you can start to see why offset is desirable. Angled, it barely covers the tire in the ditch. At least now it does cover the tire in the ditch.
Normally have the float valve on the toplink, but for this job wanted it on the side link. A quick hose swap allowed the blade to follow the contour of the road.
This is the before. Probably doesn’t look all that bad but water running in the wheel tracks like little ditches ain’t cool.
This is after one pass up and back with the backblade. It’s still pretty wet here so anything not on top already is dark, but it’s stone dust and rock so it will all be gray again by tomorrow. Definitely not done. Just step one, pulling material in from the sides so there’s something to work with.
Dropped the backblade in favor of the boxblade. One pass on each side and it was looking pretty decent. At least good enough for the crown to shed water all the way to the ditches.
Usually I don’t much like working the end of the road that ties into the public road where traffic flies by as I’m having to get right to the edge of the pavement. Have to watch traffic and what you’re doing to the road. Today, a crew from the power company was running new lines to service an adjacent development under construction. They had one lane shut down in front of our road with flaggers controlling traffic. Didn’t speak to them due to the noise of each other’s equipment but they saw me and made it clear they’d stop traffic for me for a bit. That was nice and of course I thanked them.
For grading, hydraulic toplink and sidelink is nothing short of amazing for an old guy like me that’s turned turnbuckles for decades.
Reactions: 15 users
Siesta Sundance
Oct 23, 2022
1,827
2,537
youtube.com
Started on the 1st swale on the front 10acre pasture. I will have to look at the elavation drop from the top of the hill to the bottom. It's probably 20' or so drop in elvation. Anyways, I need to capture as much moisture I can for forage grasses. I'm just winging this, never done this type of work before, lol and I'm eyeballing the routes for the swales. I probably need 6 or 7 swales and I don't want them higher than 6in. I want to keep the surface shredded or cutter friendly as much as I can. I'm gonna put the grading blade on the L305 tomorrow for a bit of a finish touch.
JP, my bull approach me while I was on the tractor, he never does that unless I have a round bale of hay. Anyways he gave me this crazy look, and I thought I better get the camera going. Look between the lift arms.
I wasn't able to catch all of his shenanigans, but here is a 7 second clip.
Distance pic of swale with a cow. She is probably checking it out to see if it's level or not. I probably failed, lol
Reactions: 10 users
BT3101
L3130 GST, FEL, TaylorWay BH W/Subfr Rotary Cutter, Pallet Forks, Grapple Bucket
Mar 20, 2016
Evansville, IN, USA
Gave my L3130 a colonoscopy, as recommended by @North Idaho Wolfman due to my glide shift trans not responding well to the hydraulic fluid I had in it.
Also bought it a new friend for it. Just arrived before dark today, so no time to unbox. 48" from Titan attachments. I know there are "bigger/better", but I am a light duty user, and I have CNC plasma and several welders if I decide to beef it up or add width.
Reactions: 8 users
nerwin
Nov 13, 2024
591
1,563
Vermont
youtube.com
Well we didn't get the dumping of the snow we were told. Still got 4 inches or so, it was fun to get out and plow anyways although it was chilly. I waited for the snow to stop and the light started to go down so I finally was able to put the aux lights I installed and they worked awesome!!
It was close to dinner time so I kept it short but I need to push the sides of the driveway back a little, wish I had a 7 foot plow! It would be easier. I'm just gonna have to close to the edge...luckily no steep drop off so not chances of getting stuck. Might do that tomorrow!
That was my day. The snow banks are getting pretty big though haha. They are way higher than what the tractor can reach haha.
6,928
Siesta, what would probably work easily is to us a two bottom plow to form your terrace. That's how they get maintained once they are built by Natural Resources Conservation Service, except they use a 5 bottom plow.
biketopia
Feb 15, 2024
356
358
Warrenton VA
