Stupid question about rear .remotes and third function.
Clevus
Ko Buddha
Oct 23, 2021
50
99
NW Michigan
2018 B2601
I am going to have the dealer install a third function for a grapple.
I like the idea of having rear remotes for a hydraulic top link. But I am not in a hurry.
Is there a reason to have them both done at the same time?
I mean, are they removing and installing the same parts over again?
4,059
2018 B2601
On a B2601 they will be removing and replacing the power beyond pipe with two hoses during the third function installation. That requires getting access to the loader valve. I would guess a dealer tech will remove the fender for access. The remainder of that job is all up front.
Installing the rear remotes requires access to the same loader valve location so the fender will likely come off again but all of the work is independent of the third function.
Combining the jobs might save a few bucks on labor but probably not a lot since there's not a lot of overlap.
Ask your dealer for a hard number and see what they say.
If you really want to save money install one or both of them yourself.
MK2525
Colorado, United States
2018 B2601
It important if you are financing with Kubota. They will only finance it all at once and you can't add it later. It's a loan not a line of credit. If it is cash then it won't matter.
