Stump grinder build
Grouse Feathers
Feb 16, 2015
1,022
11
Lovells, Mi
I have been reading your thread with much interest and envy. Looks like a high quality build beyond what most of us could do and better quality then we could buy.
I am no expert on hydraulics so I guess this is more of a question than a suggestion. Would a valve with regen, like the loader bucket tilt, solve your problem with controlling depth of cut?
Tarmy
L2800, BH76A, FEL,box scraper
Nov 17, 2009
534
498
Lake Almanor, Ca
Been following from the beginning...love your effort...nothing like figuring something out, making it and then enjoying the use of it. I wish I had some of your milling machines and skills...
Labor of love, excellent build, great effort posting the build progress...
So I have to ask...how many man hours?...And I know it doesn't matter...just figured that at minimum wage x number of hours...I might be able to afford to buy it from you...
This forum is great because of guys like you! Thanks.
Yooper
3901 LA525
May 31, 2015
1,625
755
NE Wisconsin
Yoop,
Your detailed and well written post on building this beautiful piece of machinery is undoubtedly hands down the most enjoyable post that I have ever followed!
I occasionally make a post with a few pics and it can take an amazing amount of time to do just a few pics with a good description/explanation - and here you are with dozens (hundreds?) of updates with dozens (hundreds?) of pictures. This had to eat into your work time on this involved build!!
And believe you me ---- we APPRECIATE IT!!
Bill Pace
Thanks Bill! It really didn't take that much time to post the progress of the build. The pictures do most of the talking and explaining. I'd just have remember to take them as I went along and there were a couple of times when I should have but didn't. I saved all the pictures I took to a folder on my computer. It will be fun to look at them in the future, providing I live long enough!
Yooper
3901 LA525
May 31, 2015
1,625
755
NE Wisconsin
Well, you got me to research regen valves because I didn't know what they were. It looks like their main purpose is to equalize speed on a double acting cylinder. If I understand it right from my quick research, it would speed up my cylinder to match the speed of the retract side, which is the opposite of what I want.
But thanks! I learned something new!
Yooper
3901 LA525
May 31, 2015
1,625
755
NE Wisconsin
Well, I tried to come up with a number for you, but found it impossible to get a reasonably close guess. Too many variables! I will say it was mostly late mornings and afternoons on the weekends this summer.
Grouse Feathers
Feb 16, 2015
1,022
11
Lovells, Mi
As I understand regen it is a two stage valve in the retract direction. The first stage puts valve output on both sides of the piston and the piston moves slowly driven by the difference in area of the top and bottom of the piston. The second stage dumps the fluid to the bottom of the piston and the piston moves fast. The tilt on the loader bucket has regen.
npalen
B9200
Feb 10, 2016
Beloit, KS
Add this old farm boy to the list of those very much impressed by your skills, Yooper.
If you had it to do over again, would you consider making the 3PT frame and the hydraulic reservoir as one unit? Would look something like a ballast box, I guess.
Speaking of "guesses", the second one is always the easiest. At least for me it is.:)
I found and read this entire thread today. Keep up the good work!!
npalen
B9200
Feb 10, 2016
Beloit, KS
I thought the first position on the regen valve would dump the bucket normally with the valve output going to the base end of the bucket cylinders.
When the valve is shifted further to the second position, the valve "regenerates" by adding the fluid coming out of the rod end of the bucket cylinders to the normal output of the valve thus nearly doubling the dump speed.
Could be wrong. Have been many times in the past.
procraftmike
1977 B7100DT w/B219 FEL
Jan 27, 2016
277
10
Neenah, WI
Just spent my lunch hour at work going through 29 pages of this thread. All I can say is wow!! Incredible work! If the world is going to come to an end, I'm moving next door to you....lol.
Congrats on your skills and workmanship!
Yooper
3901 LA525
May 31, 2015
1,625
755
NE Wisconsin
That thought did cross my mind, but I dismissed it for fear of the stresses causing an oil leak. Figured it was better to 'float' back there.
Thank you very much for the compliments!
Yooper
3901 LA525
May 31, 2015
1,625
755
NE Wisconsin
Well, thank you for the nice words!
Yooper
3901 LA525
May 31, 2015
1,625
755
NE Wisconsin
Yikes! I just looked at the views on this thread and we're closing in on 20K.
A little update. I ground about forty stumps this fall and other than several oil leaks, it performed without any issues. The oil leaks were all on npt fittings that I didn't tighten with a three foot extension. I'm going back to teflon tape. Don't care about the warnings!
The Greenteeth cutters show no wear. I'm quite pleased with their durability considering what they go through, including dirt.
I also wouldn't mind having twice as much horsepower, but isn't that the case with all of us tractor owners?
Yooper
3901 LA525
May 31, 2015
1,625
755
NE Wisconsin
Well, today marks the last stump on my property that I will grind with my stumpgrinder. Had to wait until the ground was frozen because it was in a low spot with seemingly no bottom. Probably have ground over 400 stumps with it and it has worked flawlessly as well as the L3901. Here is a short video of the last grind. https://youtu.be/ScgOcJ5ExgY
8,643
Your video comes up as private, we can't view it. :(
OC455
BX2350 LED ROP, FEL, Belly mower,modified snow blower, pole boom, middle plow
Sep 30, 2016
161
12
Rome NY USA
How did I not see this thread...amazing build. Just reading through all the pages has answered a few questions I've had about PTO pumps myself.
Would like to know if one of these PTO pumps can be used on a BX?
mdhughes
L3901DT
Dec 10, 2014
1,310
960
Ste Geneveive county, MO
To bad you live so far away, you could come do some of my stumps! Glad to see that you build has held up. I was impressed with it when you built it, now after 400 stumps, I'm really impressed.
How many hours do you have on your L3901? I have right at 380 and have been very happy with it.
Yooper
3901 LA525
May 31, 2015
1,625
755
NE Wisconsin
270 hours. Just did a regen at 268 and it seems like the time it takes to do one is getting shorter. Very happy with my tractor!
SidecarFlip
Banned
557
Nice job. I too have the capability to build one but not the ambition. Just bought a BaumaLite grinder.
