Howdy…I live in Colorado at 7100’. First year with a tractor(bx23s) for pretty flat but long driveway. Do I need to buy chains? Using the loader and rear blade. TIA
I have the same tractor and live at 5,000 feet in Idaho. I bought chains for mine and don’t use them. I use a front snow blower and a rear blade and have never had any issues. 400 foot drive way that goes downhill to the county road. That’s just my personal experience.Howdy…I live in Colorado at 7100’. First year with a tractor(bx23s) for pretty flat but long driveway. Do I need to buy chains? Using the loader and rear blade. TIA
Serious snow removal with a tractor (FWA or otherwise), aside from using a snow blower, will require tire chains, especially in wet snow, ice and/or steep slopes.Howdy…I live in Colorado at 7100’. First year with a tractor(bx23s) for pretty flat but long driveway. Do I need to buy chains? Using the loader and rear blade. TIA
Turf tires perform better than R4s or R1s in snow and probably better than R14s but I have no experience with R14s.This subject has come up before and I believe turf tires may perform better in the snow. I have turf tires on my B2601 and have not felt the need for chains. We (me and the B2601) have cleared a good bit of snow here in Pennsylvania. I kind of enjoyed it.
Hmmm. I’ve been using my loader and back blade for years to plow my 2000’ gravel road, with up to 2’+ of snow. I hold the loader bucket at 3” above the road and float the back blade turn around 180 degrees to avoid cutting into and moving gravel. I’m at 6,900’ elevation and we can get a fair amount of snow. The MX just blows through anything.I have been snow-blowing 3000' with turf tires first with a BX22 and now with a BX23S using turf tires loaded with Rim Guard, and a 600#+ weight box on the rear. I have never encountered ice unless the driveway is ice-covered before it starts to snow. My driveway is paved and chains make for a very horrible ride so I don't use them. I tried them once and removed them in less than 5 minutes of use. After I snowblow I scrape the asphalt with a front-mounted blade.
Using a loader for a long driveway is going to be very tedious on the operator to clear the snow. I suggest that you rethink your snow removal methods, because chains or no chains, you are headed for a very long winter using a loader and a back blade.
The MX is a lot different animal that a BX23S. The bucket is larger and so is its lifting capacity. The question asked is in relation to a specific tractor, the BX23S.Hmmm. I’ve been using my loader and back blade for years to plow my 2000’ gravel road, with up to 2’+ of snow. I hold the loader bucket at 3” above the road and float the back blade turn around 180 degrees to avoid cutting into and moving gravel. I’m at 6,900’ elevation and we can get a fair amount of snow. The MX just blows through anything.
Really? That's about 1/3 the price of what I saw when shopping this week.Tire chains for the rear of your tractor start out at about $125. That’s pretty cheap insurance to insure that you can get around safely.
