PTO shaft question with slip clutch
KennedyFarmer
L3901, with not enough attachments
Jun 8, 2015
290
Pennsylvania
I got a quick hitch. Now one of my implements shafts is too short! :eek: What is some of my options, can I just get a longer PTO shaft and mount the slip clutch to that shaft or do i need to get another shaft with a slip clutch?
Ramos
1870-1, LA203A, RCK54
Feb 25, 2016
463
Sherman County, Oregon
PTO shaft extenders introduce a lot of stress and leverage at the tractor end and are responsible for many broken output shafts. They also put your pivot point in a location that neither the tractor, nor the implement were designed for. Get a longer driveshaft. If you match the tube size and style, you can reuse your ends if they are not welded on.
5,153
947
This is an example of a COMER pto shaft.
Remove roll pins 5 & 9 and the two shaft halves are free and replaceable.
Each brand of PTO shaft will have its own profile so a COMER will not fit another brand,
KennedyFarmer
Jun 8, 2015
290
Pennsylvania
KennedyFarmer
Jun 8, 2015
290
Pennsylvania
Ramos thanks, I was thinking the same. I wanted to know what my options were.
