Post Hole Digger
2,281
What is the proper RPM for a Post Hole Digger with a 12" Auger?
Personally I would go as slow as I could dig - with enough power to dig, and the reason for that is once you bind it on a root,rock, or very hard clay - the backing out part truly sucks!
The trick is, dig a little, lift a lot !!!! Shear pins not withstanding - the best way to go is slow and steady!:)
As for a rpm - I think the 540 is still the proper setting.
4,630
What 85Hokie said! You should not exceed PTO of 300 (so your engine has good torque), but you need to be able to lower the bit with control. If you go to fast you dig deep without clearing the loosened material and you end up stalled. (If necessary slow down the PTO to be safe.)
Then you have to get a big pipe wrench and "unscrew" your auger. This usually happens in heavy clay material.
Diydave
L2202 tractor, L185f tractor
Oct 31, 2013
1,635
Gambrills, MD USA
On my Hyd unit, I think its like 60 RPM. They used to make the PTO type out of truck rear ends, so a 4:1 rear should drop 540 down to to 135 RPM, so that's my guess...:D:D
MtnViewRanch
723
181
Lakeside Ca.
WOW, some of you guys actually put the engine up at well over 2000RPMs to dig a hole? :eek: That seems crazy dangerous. I always dig at an idle, never go down more than a foot at a time without raising about 6" to be sure the bit is clear.
So down 12", up 6", down 12" more, up 6". Do that 4 times and you are down 4'. Does not take long and you don't get the auger stuck. ;)
5,483
I'm with MtnViewRanch, I dig most if not all my holes at an idle or just slightly above it. ;)
Tx Jim
M7040 HDC-1,JD 4255,Ford 6700
Apr 30, 2013
1,188
119
Coyote Flats,Texas
Ditto on digging post holes at "idle or very slightly above idle" frequently raising auger up so it doesn't cork-screw into ground
meackerman
74
Northern California
first go around using my post hole digger I got it stuck in the hard pan we have about 3' down. stalled out my tractor. that sucked. got it out without having to dismantle the auger, but I'm a lot more careful on pulling the auger up more often.
I've also tried digging in the middle of summer when the ground is like concrete. The post hole digger picked the back of the tractor up and it tilted over onto one of the back wheels....scared the cr*p out of me.
MtnViewRanch
723
181
Lakeside Ca.
How is this even possible? What type of set up were you using???? :confused:
bcbull378
GL3830,fel,brush hog,pallet forks,disc,gannon,auger,springtooth,plow,drag,ripper
Sep 6, 2011
579
27
Ventura Ca
I run mine just a hair over idel with the heavey Adobe we have here in Ca it works great. Just make sure you raise the auger every 8" to 12" you dig.
MtnViewRanch
723
181
Lakeside Ca.
It is possible. Just hook a buried root or rock, and the screw action drives the auger down, and the tractor up... :D:D
So your hyd auger has a telescoping system of some type? How can the auger go down into the ground and yet the tractor raises up. Things operate in 2 separate directions at the same exact time? :confused:
A.O.
L3540HST LA724 FEL
Feb 6, 2015
120
South Carolina
Front tires come up, fulcrums on the rear wheels as the auger screws into the ground.
MtnViewRanch
723
181
Lakeside Ca.
This is understandable, I have been referring to post #9
[quote ]I've also tried digging in the middle of summer when the ground is like concrete. The post hole digger picked the back of the tractor up and it tilted over onto one of the back wheels....scared the cr*p out of me."? [/quote]
Diydave
Oct 31, 2013
1,635
Gambrills, MD USA
Not my hyd PHD, the op's 3 PH model. I have used both types. I prefer the hyd model, flip a switch, unstick the auger, plus its easier to connect...:D:D
