New Tractor Advice for a newbie please
PaulL
2,486
1,414
NZ
The OP isn't comparing backhoe to no backhoe.
The suggestion is that he comparing a BX23S with backhoe to an L2502 without a backhoe. None of his listed tasks require a backhoe, a number of them would greatly benefit from an L sized machine.
He says he already outsources serious excavator work.
Given the constraints he provides, I'd say an L class machine is a better choice. If the OP can stretch to an L with a backhoe, great. But that's a lot more than a BX23S with a backhoe.
Harley 2e
Zd21. Zd331, mowers, Kubota 1100Rtv., Kubota 121 excavator
Jun 10, 2024
I'd agree that the backhoe is what's really pushing up your cost. If you're trying to fit a budget, you get a lot more tractor for your money without a backhoe. You can add a backhoe later if you need one, but nothing in your list of jobs requires a backhoe.
I'd look bigger than a BX for what you describe. A B is the minimum, an L would be nice. Depends if you want a MMM.
Food for thought
60 hp skid loader with
Around 2500 3500 hrs on it I prefer CASE
Front flailal mower
Back hoe attachment
There are more att.for skid steer loaders than you could ask for
Just a suggestion
Good luck
PaulL
2,486
1,414
NZ
Food for thought
Front flailal mower
Back hoe attachment
Just a suggestion
Good luck
I can't imagine trying to brush hog 10 acres with a skid steer. And I struggle with them having a useful backhoe attachment. If the OP was looking for a used machine there would be many tractor options that were more suitable.
BAP
Dec 31, 2012
2,851
949
Meanwhile, as everyone with unlimited budgets and no real concepts of a budget or how to make and stick to a budget keep posting on and arguing on here, the OP has not been back on the site since making his 1 and only post.
Hkb82
Nov 17, 2021
426
347
Ontario Canada
Typical backhoe
It s easy for the BH naysayers to be BH naysayers, because they simply have never had the instant access to a BH for those little jobs, that a BH can do best.
I don’t think anyone was being a backhoe nasayer as you called us. Realistically he said zero tasks requiring a backhoe and is predominately using it for grass and property maintenance. If money wasn’t an issue or he had no limit he probably wouldn’t have posted in the first place. Backhoes are great but not every tractor owner needs one.
when I was last shopping for tractors and specked out ones with backhoes versus ones without, I didn’t save anything by buying the backhoe at the time of purchasing the tractor vs after purchasing it. Like I said before financing it together makes sense but you gotta stay in your budget. 10-15k for some is a lot of cash. I definitely know at least two people that if it were me I’d regret buying the backhoe as one literally sits on pallets in their shop used for a few stumps I. The past 8 years. The other one hasn’t been used once I don’t think since the guy bought the tractor. To each their own personally I’d rather invest the 15,000 if I don’t have a use for the backhoe attachment.
5,103
Typical backhoe
I do absolutely agree with your hypothesis/conclusion!
If I could not afford, or did not enjoy eating fillet mignon...... I would never buy that either!
DenmanBC
Pending purchase
Aug 6, 2024
Coastal BC, Canada
Hello,
I am the OP on this discussion, and as correctly stated above I have only made one post on this site and it has taken me almost a year to reply back. Apologies to those who have been contributing to the conversation. Getting older ain't for sissies and health and family stuff took me out of the running for a while. Consequently I have not yet purchased a tractor but am still looking. The current tariff and economic turmoil may sideline me for a while yet though.
All of the above replies were appreciated and much food for thought.
Here is some clarifying information.
The potential need for a back-ho relates to my perceived need for the frequent ability to dig. I need/want to dig up patches of heavy dense blackberries and heavy broom. Currently they are too dense to mow or brush cut. Secondly I have a number of ancient solid rock piles (probably from old farming activities) that I would like to loosen and move. Thirdly, I have very uneven ground around the house with bumpy ground that is likely too dense to push flat, and my sense is that digging these solid piles flat would help with the landscaping. Finally I have a network of old drainage ditches that I would like to dig out. Yes, as mentioned I could hire someone or rent an excavator but my sense is that digging is likely a fairly common reason from owning a piece of equipment.
In terms of actual tractoring, the definite top need is for brush cutting/rough mowing so whatever tractor I buy needs to be sufficiently powered to handle a brush cutter or equivalent. With time I think it is possible that I may get rid of enough heavy brush to allow maintenance with a mid mount mower deck but that may be overly optimistic.
I went back to the local Kubota dealer recently and his thoughts were similar to those included in the replies above. 1) I may need more tractor than a BX and 2) Do I really need a backhoe.
I am still considering my options and have decided to get started by pouring a concrete pad and building a covered area to park whoever machine I finally decide to purchase.
Thanks to all for the helpful replies to my original post.
5,103
Hello,
[/QUOTE
If cost is not a major issue, it would seem that an L47 TLB would be perfect for your needs.
Cumberland Blue
Vancouver Island
I'm guessing from your user name that I'm not far from where you're at... I'm in the Comox Valley...
I hope you don't mind that I hop on your thread it sounds like I'm going through a lot of the same work on my 5 acres I bought last spring... broom, blackberries, brush, LOTS of random rock piles. We are about 1/3 forest and I'm not looking to clear it, but I want to clean up the underbrush, maybe thin a few trees. Also planning to fence the whole property for sheep in the future and do a full lawn reno, plus driveway upkeep, etc
I just did a weekend 2.5 ton min-ex rental from home hardware and cleared out an area of about an acre of thick broom and blackberries, moved some rocks, and some other general stuff... I couldn't imagine trying to do that with a back hoe on a small tractor. I thought I wanted a backhoe before, but mini-ex rental is so easy...
My next task is preparing this former area of broom for crop planting. I'm might be a little ahead of myself clearing it as I want to get a cover crop planned and I don't have a tractor yet to grade and till the area. What's could I do to get this started without a tractor yet? I could rent a skid steer... or I could get an attachment for my ATV maybe? Maybe I could get lucky and find a tractor in stock...
I've been looking and casually shopping for a tractor since we bought the property. A year ago I just figured get a BX, but pretty quick I moved up through the sizes and now I've been pretty settled on an L3902. Attachments I'm considering include a loader, grapple and post hole auger for the front. I'm going to mow with this using a rear mount finish mower, also a tiller and a box blade.
And that's where I'm at...
What do you tractor experts think?
I'd appreciate any corrections or suggestions for what I need to be doing here.
PaulL
2,486
1,414
NZ
Broom and blackberry I have cleared with my B2601 and mid mount mower, plus my FEL. I did not dig, I just pushed. I've also cleared gorse, which is harder, but I can push it over with the FEL.
The digging you describe isn't what I'd call backhoe digging, a lot of it you'd do with a FEL and a tooth bar. It's more levelling than digging. Also take a look at what you can do with a grapple, you may do a lot of clearing that way - refer this thread that popped up again recently.
I'd fill drainage ditches rather than dig them. An FEL will do that. I'd push and then bush hog blackberry and broom. I'd have a go at the rock piles with a grapple or FEL, or get a dedicated machine on rental for that. Bumpy ground is a tiller, or a box blade, or maybe FEL with tooth bar.
So, I'm still on the advice I gave a year ago. At least the B2601, but realistically for 10 acres I'd be an L. I'd much rather an L2502 without backhoe than a BX with backhoe. Sure, there are some tasks you just won't be able to do without renting. But they sound like about 5% of yoru tasks. Everything else will be substantially better with the L than a BX.
A BX is really too small for work out in the fields - it's a home and garden machine. Not much clearance, and since it's built down to a size it doesn't have the leverage and push needed for many tasks. Don't get me wrong, I had a BX for 3 year and loved it, it's a capable machine. But I had it on groomed lawn the majority of the time, when I took it in fields I bottomed it out really quickly, ran out of traction from the small tires, had a rough ride from the small tires, and found the 3pt to be quite limited in operation - the tractor is so low you don't have much range of motion. My B2601 is substantially better. You have way more property than me, so whilst a B or an LX could do the job, I think an L is the sweet spot. The L is also an economy machine, so you can get an L2502 for about the same money as an LX, and only a little more than a B2601. For your use it's a lot better buying.
DenmanBC
Pending purchase
Aug 6, 2024
Coastal BC, Canada
Appreciate you joining the conversation. Cumberland is indeed close to Denman island and your projects/challenges sound very similar. Mini-Excavator rental has been mentioned to me a few times but unless I am wrong, the Comox valley rental places won't deliver across to Denman island which makes getting the rental machine costlier and more complicated. That's part of the reason I am seriously considering a tractor with digging potential.
DenmanBC
Pending purchase
Aug 6, 2024
Coastal BC, Canada
This is extremely useful advice and much appreciated. I'm definitely leaning B or L now. Thanks for taking the time to send such a detailed reply with the additional video.
Cumberland Blue
Vancouver Island
Yeah. It may be that they won't deliver and I'm guessing they won't let you pick up either... Could be worth a call, maybe Pilon can be accomodating somehow, or maybe Central Builders. You can't be the first person on Denman looking to rent a machine.
Or I'm sure there are at least a few locals on Denman with a machine that might give you a decent hourly rate on the island to help you take care of some of the more digging oriented tasks you have from time to time.
It's not the same as having your own machine and doing it on your own time for sure, but what I did in a weekend with a mini-ex would have been tedious and time consuming with a backhoe... And I'm sure a mini-ex pro operator could have done it in a half day if I hired it out...
Anyway, good luck with your property and your tractor purchase.
I'm getting ready to cave on getting something for mine... Been a few days of continuing the cleanup of that acre area and burning debris with nothing but a pair of gloves for gear, it's not sustainable!
DenmanBC
Pending purchase
Aug 6, 2024
Coastal BC, Canada
Wow. I am shocked at what that bigger tractor and monster grapple can do. Fantastic.
My broom and blackberries wouldn't stand a chance !!
torch
Jun 10, 2016
2,656
892
Muskoka, Ont.
fence mending, light tree clearing, light to medium landscaping,
These are the only mentioned tasks that I can see might benefit from a smallish backhoe. Depending on the soil conditions, which can be a huge factor.
My place is glacial till -- primarily sand with the odd fist-sized stone. The backhoe is handy and faster, but really there's nothing it can do that couldn't eventually be done by hand.
The glacier was a bit thicker at my son's place. What sand there is filtered around boulders that are up to two feet in diameter. A fence post may require a four or five foot diameter hole by the time you pluck the jumble of rocks out of the way. The backhoe is a life saver there.
My old place was a few inches of dirt on top of limestone. A backhoe would have been useless.
DenmanBC
Pending purchase
Aug 6, 2024
Coastal BC, Canada
I've been meaning to give Pilon a call. I get all my chainsaws from them and like those guys. Good luck with the tractor purchase and let us know what you decide.
DenmanBC
Pending purchase
Aug 6, 2024
Coastal BC, Canada
Quick question Paul regarding the B2601 vs the L2502. I looked up the specs and looks like the B2601 has slightly higher engine and PTO horsepower. Your video link and feedback has convinced me that an adequately powered tractor with a digging grapple will accomplish a lot of the chores I need to complete. Why would I choose the L2502 over the B2601 if it has lower power?
Also, do you have any thoughts on the LX series with higher horse power?
Cheers
PaulL
2,486
1,414
NZ
Cheers
Refer this table I made a long time ago - when the LX2610 used to be the B2650 (pretty much same tractor though). https://www.orangetractortalks.com/forums/threads/bx-vs-b01-vs-b50.36719/
Somewhere Messicks also have a video on 26hp tractors, and Neil has a lot of good information.
Let's start with the 26hp thing. There are a lot of tractors right at 26HP, because more than 26HP attracts tighter emissions requirements. Under 26hp you generally don't need DPF, and DPF is both expensive and increases maintenance and warranty claims. There are tractors from the BX through to the L that are all 26HP.
The thing is, not all HP are equal. The BX has a 1000cc engine making 26hp, the B has 1100cc engine making 26HP, the LX is a 1250cc engine, the L is a 1650cc engine. As we all know, there ain't no replacement for displacement. The L is making the 26HP at 2200rpm, the BX at 3200 rpm. The L has way more torque, otherwise known as simple low down grunt. Kubota have also way under rated that engine, I'd suspect many of them are making more than 26hp, and that engine has way more power to give with minor tweaks. All that adds up to a machine with a very under-stressed engine that will go forever.
To be honest, the BX engine will also go forever in any sensible personal use.
Next, take a close look at what you're trying to do. How many of your tasks are HP limited? To be HP limited you really need to be either driving a hungry PTO implement (a chipper, a brush hog, a snow blower), or you're moving at a reasonable speed pulling a load (pulling a trailer up a hill, pulling a brush hog up a hill). In those situations you can use all the power that the engine is putting out.
But in many other uses, you're not HP limited. Anything hydraulic is actually limited by the hydraulic pump. The BX1880, BX2380, BX2680 all have identical pumps and loaders - they lift exactly the same on the loader. Anything traction related, a BX (and a B, and probably an LX) will spin all 4 wheels in low ratio long before it runs out of power. With turfs on I used to be able to spin all 4 wheels on tarmac on my BX. They're a small machine with a lot of power for their size, and a lot of the time no real ability to use that power.
Work with a tractor often comes down to weight. A heavier tractor with bigger wheels will do more - it'll have more traction both due to tire footprint, but also weight = traction. It'll often lift more - the L appears on paper to lift the same as the LX, but actually the L lifts it quite a bit higher. Lift capacity is related to height - you'll lift a good 50% more to 1 foot than you can to 6 foot. An L actually lifts more in real life, and certainly is has more lift capacity in the bits that aren't raw lift power - a heavier machine won't tip over as easily when you lift stuff.
Think about a 3pt implement. A single bladed brush hog is basically square. A BX2680 in theory can run about a 5 foot brush hog, it has the power to run it. But it can't actually lift it - it sticks out too far and the leverage on the 3pt will tip a BX over. And the brush hog will weigh most of what a BX does, it'll push it around in ways that mean you'll never feel safe.
To use truck analogies (and note that I'm in NZ and we don't get really any US trucks, so don't nitpick my numbers here), the F150, F250 and F350 are all available with 400hp engines. That doesn't mean you can tow the same. An F150 will haul 2,500 pounds, and tow 13,500 pounds. An F350 will haul 8,000 pounds and tow 33,000. And most people would say you'd be a bit optimistic actually towing 13,500 pounds with an F150, they'll give you a list of reasons it's not really safe, even if the specs say you can do it.
I like my B2601, but I'd really only run a 4 foot brush hog, I think a 5 foot would probably be a bit unsafe. An L in theory can swing a 6 foot - certainly it can lift it and control it. That's 50% more cutting.
But, it's very true that the L2502 is kind of made down to a HP rating. That same engine in my part of the world makes 32hp, we don't have the emissions restrictions. It doesn't come with 26hp because that's a good idea, it comes with 26hp because of regulations. It's underpowered for some tasks. Plenty of people will say that running a big mower up a hill, you'll bog down. It just doesn't have the power to run a load up a hill fast. Of course, you can just run slow instead, it'll get there, it's a tractor.
The LX is an interesting machine. On paper it has all the capability of the L, and it's a more refined machine in some ways - all the castings are a bit more refined (and therefore lighter). It's a machine that does dual duty - it's reasonably capable, but not so heavy it'll rut up your lawn and generally make a mess. For your use, that doesn't seem to matter. I normally say you get an LX if: light weight matters to you (you trailer it and have a limit with your trailer or truck; you drive it on your home lawn and you're trying to have a good looking lawn), you want a mid-PTO (snowblower or mid mower), or you want a cab. If none of those are you, the L is probably better buying. The LX is a nicer machine in some ways though - nicer operator station, loader stick etc. Of course, the grand-L (L-60 series) is the ducks nuts, so if you care about refinement then that's a brilliant machine, and it's your money I'm spending not mine...
I think an L2501 will do more work than a B2601, even though it's a bit HP limited to drag all that weight around. But if you can stretch the funding, yeah an L3302 or LX3310 will probably put a bigger smile on your face.
You do really need to go sit on them and drive them. The L is a much bigger machine.
All of this though is detail and in the last 5%. The reality is that any of these machines is so much better than a wheelbarrow and a shovel that any of them would make you extremely happy. Any of the jobs you describe can be done with the B2601. Just a bit slower and with implements sized to the machine appropriately.
I think the best advice I can give to you is to buy the biggest machine you can afford. Because once you have it, everything else you buy will be sized to that machine. So for 10-20 years, the machine will set what you can do and what you can buy. And changing once you've bought those implements is painful, you have to change all the implements. If it were me I'd go with a second hand larger machine rather than a new smaller machine.
If you're not particularly worried about emissions systems (I'm not worried), then the L3302 would be a great option. I suspect it costs about the same as the LX3310. And I think it'd be better. Either would be better than a B2601.
But if a B2601 is all you can afford, buy it.
