Thank you!
Do you have any suggestions on my starting issue.
Tractor turns over and does not want to start its like its not getting fuel. Ive replaced the fuel pump with an after market pump. Also after I get it running it will run and operate for about 5 hours then engine shuts off and doesnt want to restart.
Remove the water separator, unscrew the plastic bowl, and blow backward through the inlet passage using compressed air. It is the passage right below the shut-off valve in the separator head.
Beyond that, have your dealer connect Diagmaster to it and read the DTC's to diagnose.
