I have a L3650 GST with the front loader and the tranny has started to get in a bind when trying to put the shifter in forward gear. When the tractor is OFF the shifter and tranny works perfect. I can move the shifter from forward to reverse all day with no problems while the tractor is off. Once I start the tractor it goes in reverse everytime, however when you try to put it in forward the shifter and tranny seems to get in a bind. It takes about 7-8 tries using the clutch and moving the shifter lever from reverse to forward before it will go into the forward gear.I have changed the fuilds and filters and that didn't fix my problem.All thoughts are helpful,thanks.
