L2501 PTO Control
scottz
1988 L2550DT-GST 2001 BX2200D HST 2016 L2501 HST
Nov 27, 2015
60
Colorado
I have an issue with the PTO gear shift lever on my 2016 L2501. I recently purchased the tractor with 259 hours on it. The PTO works properly during engagement. However, when I move the lever to the disengage position, the control shaft does not move all the way to disengage. The previous owner tied a string to it in order to "help" move the shaft into the disengage position by pulling on it. The shaft is moved into the engage position by the gear shift lever/cable. It is designed to move into the disengage position by a spring when the cable tension is released. I almost seems as if the spring is not strong enough. I removed the control cable from the shaft to make sure the cable was not binding; it is not. Thoughts?
3,605
New spring?
Add a helper spring?
Adjust the cable?
Lube the shaft?
scottz
Nov 27, 2015
60
Colorado
New spring?
Adjust the cable?
Lube the shaft?
Thanks, A new spring (part 050) is on order. The cable is not the issue; I disconnected it and the shaft will still not return to the disengage position on its own.
whitetiger
Nov 20, 2011
2,679
1,180
Kansas City, KS
Lube the shaft where it extrudes from the case, right at the spring, and turn it back and forth a couple of times with a crescent wrench or pliers. It will then work like a new one.
scottz
Nov 27, 2015
60
Colorado
Thanks for the help; that did it. Amazing what a little oil will do. Now I feel bad about bothering you guys with such a trivial issue.
Thanks again.
whitetiger
Nov 20, 2011
2,679
1,180
Kansas City, KS
Call the dealer, there is a bulletin for that issue.
TSB-2023-028-E-R1
FIX AS FAIL EXTENSION: L-Series; PTO Lever Does Not Return to Neutral Repairs described in this bulletin may be made only in the event of a failure.
Product Line: L-Series Model: L2501HST, L2800HST, L3200HST, L3400HST, L3700HST, L3800HST, L3301HST, L3901HST
L2501HST 50001 to D7056
Units are covered for 5 years after the original date of purchase.
The PTO lever may become stuck and not return to neutral. Solution: If the PTO lever is stuck and does not return to neutral, install the LEVER, KIT (S-PTO) per the procedure beginning on page 3. Note: If the PTO cable is damaged, replace the PTO cable with the appropriate cable listed in the K-Pad for your model
