I have an issue with the PTO gear shift lever on my 2016 L2501. I recently purchased the tractor with 259 hours on it. The PTO works properly during engagement. However, when I move the lever to the disengage position, the control shaft does not move all the way to disengage. The previous owner tied a string to it in order to "help" move the shaft into the disengage position by pulling on it. The shaft is moved into the engage position by the gear shift lever/cable. It is designed to move into the disengage position by a spring when the cable tension is released. I almost seems as if the spring is not strong enough. I removed the control cable from the shaft to make sure the cable was not binding; it is not. Thoughts?
