L2350DT flywheel resurface or replacement?
8,277
OP, I'd machine that flywheel in a heart beat and never think twice. If you take it to a good machine shop, they'll likely also have spacers you'd add between the crank and flywheel that is the thickness of the material removed.
He doesn't need the flywheel machined, he just need a pressure plate that the rivets have been installed properly. ;)
1,732
Well we figured it out. Pressure plate is being held off too far and not allowing it to engage fully when bolted down. The rivets are holding it off. Going to order Kubota branded and get her going
Well the good thing is that you already have it apart so is easier to fix now!:unsure:
It is good that you were observant enough to see what the problem was!
DrakeRemoray
L2350DT
Jun 24, 2024
71
24
Alvarado TX
Success!!! Found a used pressure plate shipped to the door for $58!! Installed and runs like a champ!!…except for suspected diesel engine knock. Lol. Always something. Have another thread on it started.
Thanks for the help everyone! You guys have been AWESOME! 👏
