L210 flywheel ring gear
141C5
Kubota L210
Jul 23, 2024
11
Hazle Township PA
maybe a real long shot...but is that ring gear used in ANY other Kubota engine ? Maybe take the dimensions and see IF there's another engine,another make, that used it ??
How many different tractors was THAT engine used in ??
I don't know how old it is but, way back, mfrs tried to use same parts, over and over, to reduce costs.
Maybe under a different part number ? Different engine (Mitzi or Saab or ??? )
Just trying to find a straw that works for you.
Did take dimensions and so far no good. From what I found only the L200 and L210
4,470
hmm, maybe look at the tranny model/ case part number...see if IT is in something else.
TD says 1972-1973 so a real long shot if ANY 'grave yard' had any.
600 for a new gear is steep BUT if you really, really want to keep the beastie, that's OK, BUT what about OTHER parts !!! Can you GET starter, pistons, rad, tranny gears, whatever for it ???
Hate to see you spend 600 and then find out you CAN'T get the next piece of the puzzle !!!!
'20 HP' engine..maybe something new has a ring gear that will fit ? If it has a 9 tooth starter gear, it might ? Similar size,HP, etc.
Too bad there isn't a 'universal ring gear selection chart' on the internet......
