Hello,
I'm new to this forum. I recently purchased a Kubota T1600H Diesel (Serial#13886) with just above 500Hrs on the hour meter. Unit is in great shape except for a few issues that I am trying to fix and I'm in need of some advise.
1) Intermittently, turning off the ignition does not turn off the engine. I figured it is a faulty diesel shut off solenoid and replaced it with a Kubota OEM solenoid bought at the dealer. Problem still exists. What else should I look for?
2) Mower deck is in a bit of rough shape. There is a 2" by 2" rust hole under the mower shaft. Also 3 sides are cracked around the mower gear box (Pictures attached) Can this be repaired? The middle blade also sits lower than the rest because of this.
3) Drive shaft going into the hydrostatic transmission has a little bit of play in it. Very minimal. I hear no noise when using the mower and it functions as it should. Seller suggested replacing the Sub assembly cover (Part#70090-33030) Supposed to be a known problem with the hydrostat on this model. I looked for this part# on the Kubota website and did not reference to anything on the mower however I was told it is an updated part due to the fact that Kubota had issues with the prior model of sub assembly. What are your thoughts?
4) Parking brake does not work. Meaning if I press the parking brake nothing happens. How do I check to see what is wrong?
Any help is greatly appreciated.
Thank you!
Thank you!
