Is this a third function setup on my B8200? Can't find any info on it
JUSS10
Kubota B8200-HST
Mar 2, 2021
34
West Michigan
I wonder if the original connections were meant to be banjo style fittings. M12x1.25 seems to be a pretty popular banjo bolt size.
Very well could have been since a lot of the main lines on the machine are banjo fittings. I just can't find any info on the line set or lever other than what is mentioned in the WSM.
This is the fitting I think I'd try if I were to start over. I actually order two but haven't swapped them on yet. Its aluminum but according to the WSM there is only 800 PSI max on the aux spool so I'm guessing it would be just fine.
FlatlandTransplant
B8200 with SSQA converted loader and a X300 yard tamer
Feb 18, 2017
23
19
King George, va.
JUSS10
Kubota B8200-HST
Mar 2, 2021
34
West Michigan
Not sure what you mean by switch in the third photo. If you are talking about the knob, that’s for your 3 point to adjust the drop speed.
What is that single hydraulic line out the back for? What’s it attached to?
8,043
He's referring to the left side selector.
Not sure if that will do it or not, it might, as the b7100 had that option.
Arnoud
Kubota B8200 HST 4wd w. Loader
Mar 10, 2022
The Netherlands
I know the round know for adjusting the speed, I ment the switch (small rod) a little higher in the 3rd picture.
Arnoud
Mar 10, 2022
The Netherlands
I know the round know for adjusting the speed, I ment the switch (small rod) in the 3rd pic a little higher
FlatlandTransplant
Feb 18, 2017
23
19
King George, va.
Mine does not look like that with switch thing by the knob. It is odd that the hose goes to the left side of the tractor from that outlet as well. Can tyou take more photos?
