I wanted to clean up my glow plug connections - started with the middle one first and then realized that even as I unscrewed the "nut" - it hits the intake manifold right at the end (see red dot). Nothing is bent.....so what to do???? See picture.
And IF I wanted to remove glow plug(s) - socket will go there without problem? Anything special to do there for removal? Or same treatment as an old fashion spark plug when removed? Should engine be warm? or best to remove cold?
those been down this road - I'd like your advice!
