Fuel consumption
twomany
B7200
Jul 10, 2017
793
138
Vermont
As well as using a real clock and not the tractors clock, as I've been told that some tractor clocks vary with rpm's.
That's my 2¢, I'll "SHUT UP, SIT DOWN" now.
Ron
All "good tractors" record time as a percentage of full rated rpm. There is no sense in racking up time at idle. Let the records show use and not the time one forgot to turn the key off.
fit a Hobbs if "time" is the concern.
Stmar
B2650HSDC
May 23, 2017
906
42
Buffalo, Wyoming
B2650HSDC: just breaking it in and the first 30 hours = about 7 gallons, so that is over 4 hours per gallon. 1/4 gallon an hour vs. 1 gallon per hour with my 8Ns, very happy with that consumption. Will it get even better after break in? That would be good to know if anybody has had any experience with a new machine.
69 SS
2015 L3901 HST,with Canopy,LA 525 FEL with SSQA bucket
Sep 26, 2015
103
21
Ft. Inn sc
Posted in What did you do on your Kubota today? Last weekend. L3901 ,16.1 hours on tractor clock,topped off before job and after. 16.1 hours @ 2300 rpm @ 540 rpm bushhoging food plots that hadn't been done in 2 yrs. 7.9 gals. Diesel turns out to be .5 gal/ hour. 17.47 $ premium diesel @ 2.219 per gallon. Temperature in mid 90's humidity in 70 % range. Done between 12:00 sat. Till after dark,and 7:30 ish til 2:00 ish, 99% time running at high rpm,only slowed motor to load back on trailer and maybe 2-3 mins gradual slow down rpm before shutdown. Had been hoping to get an extended run just to see what " Big Orange" could do . My 60 yr old butt/ back/ and other unmentionables still hurting. Good luck to all on your projects.
