Fuel consumption
Orange Turbo
MX5100, pto13000kw, Loader, Ripper,Plow,Disc,Mower,Forks,3pt spreader,Box Blade.
Feb 2, 2015
175
Mo
Have you ever check how much fuel you use in a hour?
Just messing around wile mowing today, Topped the tank off, Than mowed for 1-hour, and topped off again.
I was quite surprised the MX Used 2-gal, I kept it @ 540/550 on the pto. No lugging, just a constant smooth ground speed.
Would like to see some comparison's on different size machines.
Please add your HP..
Mines around 50hp.
Cal270
4060 HSTC,LP1258,1672,1860,1672,ballast box,& HermanSupply fel snowplow
Jun 23, 2014
104
Mid-Michigan
Have 136 hours on this Kubota, .6 gallon average.
It is a Tier 4 engine so run 2000 rpm as a minimum.
I think this is very good fuel use for a tractor of this size.
2,859
All I know is that I can cut the same land with my BX and use about half the fuel than what I used in a gas motor, same size tractor and deck. Yeah she do just sip fuel,,, makes me happy:D
4,657
I went from five gallons of gas to do my two acres down to 1 1/2 to 2 gallons of diesel :D if I can keep the yard cut short I can get three mowings per tank/ five gallons of diesel :D
DocGP
117
SE TX
Yep, my MX 5100 seems to burn about 1.5 per hour. I am glad she is pre Tier 4, as I can run it about 1800 rpm all day. My 20 yr old L3010 seems to be about .6-.7 per hour at 2000 rpm, but it has about half the size engine as the MX.
Doc
sawmill
bx24 backhoe/fel, 48" Bush mower
Nov 16, 2014
560
105
ione, washington
My BX24, hauling limbs and pine needles, etc. to the burn pile, doing a little dressing up with the fel at 2200 rpm uses about 1 1/2 qts an hour. Plowing snow with the fel it uses about 2 qts an hour at 2200 on average.
Tallahassee Kubota Man
M5140HD/LA1153/LandPride RCF2072/DirtDog disc/RakeMaster grapple/Caroni tiller
Mines around 50hp.
I don't have any exact figures, but don't believe my M5140 uses any more than 2 gals/hr doing heavy loader work, bottom plowing or mowing some really heavy bahia grass.... probably less. Otherwise it's probably around 1 - 1.5 per hour. Will try to keep some records on fuel consumption in the future. My tractor is around your hp, but a little heavier...... 52 hp.....4550 lbs.
Orange Turbo
Feb 2, 2015
175
Mo
Ya, mine was at a constant 2700rpm, @540.= 2-gal....72'' woods,,, I'm sure mine is around 1/1.5 wile using the foot throttle.
MadMax31
BX23S, 60" MMM
Nov 5, 2014
766
New York
B7610, 24hp. 11 hrs of use = 5.3 gallons. Hogging at 2200 rpm, not 2800. FEL work, York rake.... Im not fond of cranking small motors if I dont need to.
Bluegill
Jan 11, 2012
1,560
Success Missouri
L3800DT, 38hp, 1800-2000 rpm mowing with 5' hog, 1 gal per hour max in heavy grass, 1/2-3/4 gal per hour for lighter mowing, box blade or FEL work.
Little Orange
Kubota BX25D TLB, hitch frame, FEL forks, 3pt steel ballast and back blade
Dec 8, 2013
114
Comox Valley, BC Canada
BX25D TBL has over the last year and half been very consistent at 1.36 liters per hour which I think works out to 0.36 gph and that digging and loading; no joy riding and no long idling periods and no lawn mowing. RPMs vary higher with the hoe and lower for the moving soil.:eek:
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,440
73
Rocky Face, Georgia
All depends on the task but my M9000 (92 hp) burns just over 1 gph, and that's mowing hay, baling or pulling a batwing. It uses less than that doing lighter work.
My L3000 (32 hp) burns around .5 gph on average.
Orange Turbo
Feb 2, 2015
175
Mo
WOW, That's Excellent for a 90hp machine. I have always thought this 50hp was a little thirsty. I'm in the process of figuring fuel usage (ball park) with the generator at 540 pto it needs.
sheepfarmer
Nov 14, 2014
4,444
661
MidMichigan
Just checked the dash reading on my L 3560 and it reads 1.5 l per hr, or 0.396 gal per hr. Tier 4 with dpf, naturally aspirated. 76 hrs, 3 regenerations, usually run in auto throttle so variable rpm, mostly hauling manure etc in the bucket, or blading or raking stuff.
Bulldog
Mar 30, 2010
5,440
73
Rocky Face, Georgia
I've asked this question before without much response from the others. I fear they thought I was going to try and turn it into a oil debate. I'm glad your having better results than I did. :D
Orange Turbo
Feb 2, 2015
175
Mo
Well, I was kind of surprised when I started running at PTO speed, I would never thought it would do 2-gal... Before just doing ripping, box blade and loader work it didn't seem to bad, But of course it was well below 2700 rpm.
Orange Turbo, I didn't realize your tractor requires 2700 rpm for pto. My 52 hp is only 2295 rpm. Different designs I guess, but the engines are very similar.
Orange Turbo
Feb 2, 2015
175
Mo
Ya, 2700,(standard).... the hydro's are around 2650. Anyway, I Should of worded the original post a litter diff:
Like: How much Fuel will your machine use @ 540 pto in an hour.:rolleyes:
otter
L3800, LA524 loader, BH77 backhoe, thumb, box blade small wood lot log grapple
Sep 26, 2014
52
Chase, Alaska
My L3800HST uses 1 gallon per hour whether I am using the backhoe on stumps or dragging a box blade.
Yes, to compare some parameters need to be established......like @540, under a load, etc... Probably need a minimum number of hrs operating to calculate fairly accurate fuel usage.....like at least 4 hrs?
