BX2370 run away
number two
B3030HSDC L2501HST
Mar 26, 2021
357
168
Northern Lower Michigan
Most likely an unusual freezing humidity problem.
Had the tractor been warmed up when this first happened,this thread would've never happened!
Glad you're OK now!
Good Luck!
6,545
I have had all 3 since new.
They all bark hard & then settle down in maybe 2 seconds or so, & run at where the throttle is set(idle when I start them) The tachs never show the engine running wide open. It is like a bit of extra fuel for starting. It seems like the governor would open them until rpm comes up to set point.
Many older truck diesels started open as well.
I have had a couple tractors with rosa-master pumps and they seem to do the same?
Kevin - - I just got back to this.
I think what you're seeing is normal for your equipment.
I thought it odd that all of your equipment, as well as older trucks had same problem.
What you deem as a "Run Away" for 2 seconds is far from it. Normal operation.
Here's a little article about Run Aways.....much different from what you describe.
Diesel engine runaway - Wikipedia
kevinj
L3940hstc - B7500hst - BX1860 - Farmall 560D - Farmall M
Jun 4, 2018
99
Exactly.
A runaway as someone described earlier is not my experience with a runaway.
The old Detroits could runaway with stuck rack or many engines have runaway from turbo oil as well.
I seen an old detroit runaway from sucking gas fumes from a station vent while unloading.
The older diesels all seem to start with the gov wide open come right back to the throttle setting.
The last big truck I ran had an x15 cummins with full electronic control and that behaved a whole lot different!!!
