Guys, I have an idea about a contraption to mow the water edge of my pond bank with.
Something on the 3pt like a carryall or pallet forks, but with a frame of square tubing that extends out to the sides of the tractor XX Feet. Attach a push mower deck on one side and counter weight on the other side. This would allow driving along the water edge 2 or 3 feet up on the bank and mow the grass right at the water line.
Was thinking that I could use differnet size of tubing and drill holes and use a pin to allow sliding the mower / weight in and out for adjustment. Also, this would allow to switch sides with the mower if needed - or also to collapse to narrowest width for storage while it wasn't being used.
I don't need some big elaborate contraption, as it would only get used maybe every other mowing or even if it was every mowing, it would only be a max of maybe 10min use each time. Plus, a used push mower should be able to be found cheap.
What do you guys think?
Here's a crude sketch of what I am thinking of.....
![](http://i232.photobucket.com/albums/ee238/number9st/Kubota%20L3800/MD1_zpsb8625662.jpg)
