Anyone try these (BX tractor upgrade)?
Yotekiller
Sep 29, 2023
459
576
Southern Indiana
Excellent work guys! Now I need to get this info for my L2502. I had to cut wood last night when I got home and forgot to get the measurements I needed.
5,505
Locate cylinders for it to increase the lift capacity a bit, and restore my hydraulic PSI back down to factory.
Unless they changed from the LA525 the OEM cylinders are 50mm bore = 1.97". Moving up to a stock 2" bore only nets you a 3% increase in lifting force. A 2.5" cylinder is a rather hefty 61% increase.
How much did you bump the pressure?
Yotekiller
Sep 29, 2023
459
576
Southern Indiana
Unless they changed from the LA525 the OEM cylinders are 50mm bore = 1.97". Moving up to a stock 2" bore only nets you a 3% increase.
So I would need to jump to a 2.5" if it would fit. Don't recall seeing a 2.25 while I was looking at them.
I bumped up 300psi to 2650.
Yotekiller
Sep 29, 2023
459
576
Southern Indiana
Thats about a 13% increase. I think you are stuck with the pressure boost.
I am ignorant when it comes to this hydraulic stuff. So going from a 1.97" bore to a 2.5" bore is only a 13% increase?
Edit: I see now you were saying 2.25 is only a 13% increase. Hopefully I can find some 2.5's that will fit.
5,505
No - 2.5* cylinders are a 61% increase. If you went that big you would have to be careful you did not accidentally lift too much and damage the loader arms or possibly the tractor.
Safer to stick with the higher pressure. The worst thing there is probably slightly reduced pump life
WI_Hedgehog
Apr 24, 2024
717
955
Milwaukee, Wisconsin, U.S.A.
That would only be the case under maximum load though? Normally the valves are in bypass and there's no pressure or additional wear on the pump under No/Light/Medium load, only under Full load?
(Full Load would include topping-out the 3-point hitch and mower lift, correct?)
5,505
Thats why said a slight decrease in pump life. In fact I almost said negligible.
The only time the pump is at the elevated pressure is when actually lifting the added weight or you have a cylinder stalled. Thats a very tiny fraction of run time.
WI_Hedgehog
Apr 24, 2024
717
955
Thank you for confirming. I'm new to hydraulics so double-checking pretty much everything at this point, because it's far better to ask than break stuff due to ignorance.
5,755
Pretty sure going to a bigger bore, usually means slower travel, as more oil needed to fill the cylinder.
aww, what's the fun in building it right the first time ?? You learn from mistAkes.
Trimley
BX23SLSB-R-1 plus additions
Jul 25, 2023
1,181
872
PNW-WA
I dont think that picture is taken with the front wheels off the ground but from that angle you cant tell.
Buy lets assume they are anx he has done what you think.
HPBX300 DIMENSIONS
Retracted length = 20"
Stroke = 13.8"
Extended length = 33.8"
I dont need to measure cycle time I can compute it. For a fixed flow rate it is proportional to volume. Since he increased volume 37% the cycle time will increase by 37%. Thats simple arithmetic.
EDIT
The OEM cylinders are actually 40mm bore = 1.58". Redoing the lift force arithmetic using that number gives ypu a 25% increase in lift force with a 1.75" cylinder and 61% increase with a 2" cylinder.
Here's what I've acquired so far.
Rod diameter = 1.125" (1-1/8")
Cylinder OD = 2.142 (2-9/64")
Pin to Pin
Min length = 20.875 (20-11/16)
Max extension = 35"
Stroke = 14.125 (14-1/8")
I've searched for comparable cylinders, and found very close options, however the inlet and outlet are in the wrong position.
5,505
Pin to Pin
Max extension = 35"
Post a link to your cylinders. Port location should not be a huge obstacle.
8,956
Is this what Kioti does to get "better" numbers for their tractors i.e. use larger hydraulic cylinders with more stroke?
6,989
Just an observation, I mentioned in another thread somewhere that a friend of mine bought a Mahindra several years ago.
Don’t recall model number, but about a Kubota B series equivalent.
Major selling point to him was a supposed loader lift capacity to be nearly 2,000 pounds.
Tractor doesn’t weigh that much.
8,956
What a shocker that some manufacturers use smoke and mirrors to sell their products. 😂 I admire Kubota's conservative and understated approach. It seems that they consider the system in its entirety and have a sense of how the equipment "should" be used.
Trimley
Jul 25, 2023
1,181
872
PNW-WA
MORE POWAH
I'm completely satisfied with my little tractor, it serves my needs very well. I spoil it, in a strong sense. I pet it and pat it and rub it's belly. In return, it's always there and ready in my time of need.
A little Spinach will help it along the way.
