Adding Aux Hydraulics to a B6000
BigBadJohn
B6000 4WD with FEL and a box blade
Oct 9, 2017
Saint Libory, IL, USA
Hi John,
I think I have attached a few pictures of the loader to this message. The subframe has two components; two heavy steal rails that run from the engine block back to the rear case which support the loader posts. Then there is a another piece mounted to the front bumper. Tubular support rods connect the top of the posts to the bumper. There is also a small tube and flange which supports the hydraulic pump. This is aligned so that the pump pulley lines up with the fan pulley on the engine.
Hope this helps
Todd
View attachment 258 View attachment 261 View attachment 259 View attachment 260
Hello, sorry for the ancient thread bump but I was trying to identify the loader on my B6000 and this one looks a lot like mine with the curved back to the bucket, valve stack and mounting location, and the tubular frame supports
The pump and pump bracket look identical as well
I was hoping to find what model number this attachment is so I can download the owners manual, parts manual, and service manual if one exists
Thanks in advance!
John
Marc Richer
B6000
Mar 21, 2025
yep, i used compression fittingson my install , work just fine with not a sign of a leak anywhere.
you can just see one of the connections in the bottom of the pic below, thats the hydraulic line going onto the 3pt hitch, i just cut a small section out big enough to allow me to get the two hydraulic lines and fitting connected up.
also replaced the twin bucket rams for a single item,also works well with no probs at the moment.
rob
Can you confirm if the top or bottom line on the pump is the pressure line?
Marc
