So just as the title says, had anyone ever replaced a bx 80 series transmission with a transmission from a 50 series machine. They look identical but the trans case part numbers are slightly different. Advice needed. Thanks.
The reason I thought they were similar is because the parts that attach to the case itself are the same parts that go into the 80 series trans. Is it different physically and not swap in? I see that your a Kubota tech so I very much value your opinion. Thanks.You might want to look again, they are very different.
It appears that there is a bearing and an extra support rib on the case extention for the axle housing.curious, so I looked up both BX2380 and my BX23S, seems parts are the same, the BX2350D is different though.
you can do a 'split screen compare', open two 'parts finders', one for BX2380 other for BX2350 and go page by page, checking the parts and numbers. yes a rather tedious process but best(?) way to know for sure.
Yes, the case numbers were the most obvious. Just sucks as I found a good used trans but it was out of a 2350.you can do a 'split screen compare', open two 'parts finders', one for BX2380 other for BX2350 and go page by page, checking the parts and numbers. yes a rather tedious process but best(?) way to know for sure.
Yes, I have spoken to him. He seems like a really good, sincere guy. He has the 2350 trans that I am posting about. He says that it will work but whitetiger says that it won't. I just don't want to ship something across the country and not have it work. I am having the dealership install it as this type of thing is out of my wheelhouse. I just need some good advice. I let him know this morning that I wouldn't be purchasing the trans. It's only because I can't get a consistent answer. The dealership doesn't know, just that the case numbers are not interchangeable. So for now, I'm back to square one.There is a member here (@Mountainman) that has a salvage yard (in Alabama?) that may be able to provide you with the part or assembly you need.
Contact him at his website https://mossycreekoutdoors.com/
Pictures pretty much sun it up.so... back to square one....
What IS wrong with your unit ???
