How Hard to De-Green an MX5200?
Mr Haney
L3710
May 23, 2022
170
26
FL
I saw an ad for a Kubota MX5200 with 1500 hours. The price looked nice to me, but this thing has the wonderful emissions stuff that requires high revs and can result in $$$$$$ repairs.
I would never, ever violate any type of environmental regulation, ever, even though I run my tractor about 30 hours a year and could never make a dent in the pollution problem, but just as a matter of interest, how hard is it to get rid of all that fine emissions stuff on this particular tractor?
8,247
About $4K
And if you ever need work done to it in the future you can not take it to a dealer.
Most dealers will refuse to do any work on it.
If your only using it 30 hours a year it's simply not worth the expense and trouble.
The MX5200 is a very stable emissions system and requires just about no effort to maintain.
Firefight100
MX5200
Apr 3, 2021
91
72
63379 troy mo
I have a mx5200. And i put maybe 50 hrs a year on it. The emissions is not worth worrying about. You'll need to do a couple regens a year. When mine calls for a regen, I just run it up the road at full throttle for a mile and back home or I continue roto tilling and everything is complete. The mx is a good hd tractor
8,136
You asked "how hard" .... and the answer is not hard at all. The cost of adding a turbo to an L2501 is about the same as getting the ECU reflashed. If you don't want to gut the DPF then you'll need to make or have someone make up a custom exhaust from the turbo back. Easy to do if you have any fabrication and welding skills and a 2" mandrel bent exhaust kit from Amazon or similar.
Whether or not it's worth the cost, effort and risk is an entirely different conversation.
Mr Haney
L3710
May 23, 2022
170
26
FL
The big concern would be that it would fail and I would have to spend thousands and wait a month for the dealer to fix it.
This is all good info to have.
8,136
One approach would be to buy the MX5200 and use it, and if at a later date you have a DPF/EGR issue that isn't covered by any warranty , then rather than spend a lot of money on repair or replacement, you could have the ECU flashed and gut the defective DPF system if that system is junk. That would very likely be far less expensive than paying for parts and labor to fix any problems.
Go to Messick's.com and price out the the various components of a DPF system. They are very expensive.
3,307
The other "up-side" to this approach is that, if in the future it does happen, then most likely someone else has had the same problem and has already done the "heavy lifting" for you, and posted how to do it somewhere. (y)
Hoserman
Kubota BX2380
Aug 1, 2022
Grayling, MI.
Buying used "anything" is always a risk unless you know what you are buying has been taken care of. Like Runs with Scissors said "most likely someone else has had the same problem and has already done the "heavy lifting" for you, Good luck on your choice.
