I have a L4400, 703 loader and 6’ bucket. Are there any good options for bucket hooks rather than welding?
thanks in advance,
john
thanks in advance,
john
While that looks Neeto, it's one use away from bending the snot out of the bucket.Just another option in case you haven't see it.
No drilling or welding and you can store them in your toolbox.
Maybe I misunderstood the issue but I thought pulling the cylinders out all the way under a load would damage the seals. Not a bending concern, but putting to much pressure against the seals.@Squirrely Baker
In the first pic (copied from out website I think), the cylinders are in tension, and no risk of bending. Lifting to the max capacity of the loader is no issue like this.
Cylinders (rods) bend when they are at full extension and they are forced to try to compress, like when backdragging with the edge of the bucket.
Overthinking is how I ended up with a tractorThe long and short of it is if you use the loader as intended and within capacity, there in NO issues.
People get in trouble when that start yanking and pulling hard with the loader, it's not meant for that. It's designed to LIFT and PUSH, other activities are trying to pull the loader off of the tractor.
Don't overthink it.
What tractor/loader/bucket do you have?
Your lift capacity is about 1000 pounds, you won't hurt anything adding hooks.LX2620 with a 535 loader and the 54" quick attach bucket.
