LX2610 block heater location
mrrlyoung
LX2610HSD, LA535 loader, BH77 backhoe, LX2963 snowblower
Jul 16, 2023
59
California
We run Kubota 15w40 since it fits our temperature range. LX2610hsd. I have an old 38 watt magnetic block heater that I'm thinking of using--why not.
Looking at the engine from above, no location jumps out at me. I also wonder if it would be better on the transmission. The lowest temperature we are likely to start the tractor is maybe 5F, and the highest is maybe 100F. It has always started OK at lower temperatures, but whether it would still be happier with a block heater I don't know. Thanks
7,998
A magnetic block heater is pretty much worthless on almost all kubota's, there just isn't too many flat locations.
Now here is the most important detail, your transmission is Aluminum so a magnetic heater is worthless.
If you really want a heater get and install a block heater.
I'm a heck of a lot colder than you are and I rarely need to use a block heater. 😉
mrrlyoung
Jul 16, 2023
59
California
Thanks. That's useful and answers my question. (I'm an ex-Sagle/Sandoint resident. I visit from far Northern CA whenever I can)
Bee-Positive
BX1880, FEL, Tooth Bar, MMM, QH, Ballast Box
Nov 16, 2022
75
122
Amsterdam, NY
I agree with Wolfman, 10 below here this winter and diesel gelling is a bigger issue than engine turning over. Since you already have the old magnetic heater you could try it somewhere, just make sure you strap it good so it doesn't rattle off and break something important or get run over.
7,998
How long ago did you move away?
And if your ever up here shoot me a PM and we'll meet for lunch or something.
SAR Tracker
Nov 17, 2020
229
325
Central Oregon
Agree with previous posters - sufficient glow plug time does a lot for ease of starting. I've had snow on the ground here since mid October, and haven't needed a block heater. Antifreeze is kept up to date, and tractor is stored in an un-heated shed. Avg temps here in Central Oregon have been in the low 30's, with most nights in the teens and below.
mrrlyoung
Jul 16, 2023
59
California
I moved away in 2011 after living there for 10 years. Loved the moose in the driveway but not so much the mountain lion tracks outside my door in the morning snow! Nice country.
2,690
Heating the oil helps ......... the OIL. Not the machine much. 15w flows about the same as 10w so it still flows well in cold.
Get a heater for the coolant - this will slowly heat ALL the components, well NOT the oil, but will heat the block and head - there is a point of NO return, about an hour will be about as long as you may need to go. After the hour the heat will be lost to the surrounding air.
Glow the plug longer than you THINK you need to - this always helps!!!
7,998
It's changed sooooo much since then! o_O
This is why we have wolves, keeps the other scary critters at bay. 😉
mrrlyoung
Jul 16, 2023
59
California
What about 'burning out' or otherwise damaging the glow plug if heated too long?
I probably won't do anything, but I just saw dipstick heaters, which peak my curiosity.
Donystoy
Dec 10, 2013
634
283
Binbrook, Ontario
Had my B7200 from 1985 until 2022 with the first 35 years in an unheated building. No heater or fuel additives. Never any issues starting it on the coldest days. Just an occasional battery charge or tender. 2300 hours.
nbryan
Jan 3, 2019
1,279
810
Hadashville, Manitoba, Canada
It may be a bit colder here yet in S Manitoba than N Idaho and I also rarely need the block heater. A few times at least I've forgotten to plug it in when -20C even colder, yet tried and it ain't pretty but a good long glow and she coughed to life. I attribute at least some of its ability to cold start to rotella T6 5w-40 engine oil, and of course a healthy battery. But even 20 minutes on the block heater when I gotta get going makes a big difference.
6,148
Others mentioned it - - I was concerned when I didn't get a block heater on my BX years ago.
I've since gone to 5w-40 full synthetic motor oil. Really helps with cold starts.
After that, I haven't wished I had a block heater.
I've blown snow as low as -8*F.
River19
B2601, RB1560, BB1260 and BX2830 blower
Sep 10, 2020
335
553
NH/VT NEK
Here in NH we have the typical New England cold temp range, 30 to -20F, but the coldest I usually run it is 10F or so. I have a block heater but have not installed it as of yet. I usually run the glow plugs for slow 7 or 8 count and it fires right up with a small protest then let it warm for 10mins or so.
When people say "run the glow plugs longer than you think", how long are we talking? Like I said I do a slow 7-8 count.......so call it 10 seconds or so......
